Exported Image does not display the chart itself
Wladi
Wladi New Altair Community Member
Hi all,
some of my colleagues and I have a issue to export an img as svg or png/jpeg. The chart itself is always missing while the RapidMiner  Studio is still visible. I have 12 dimensions, but only 10 selected.
First picture is the exported picture and the second a screenshot.
thanks in advance
Best Answer
  • David_A
    David_A New Altair Community Member
    Hi @Wladi,
    some quick questions to potentially boil down the issue:
    What mechanism did you use for exporting the image? The sandwich menu highlighted in your second screen shot?
    Does it happen with all mentioned file formats?
    What operating system and Studio version are you using?
    I'm asking all this, because I tried and failed to reproduce your problem so far.
    Best,
    David
  • Wladi
    edited March 2020
    Hey David,
    thank you for you quick answer.
    I did File->Print/Export Image and it doesn't work, i also tried today. Yea for all formats and i am using win 10 64bit with RapidMiner Studio Educational 9.6.000
    I figured out, that it is working if i use the sandwich menu on a scatter or histogram. But if i want a scatter matrix, the menu isn't visible.
    Best regards,
    Wladi
  • David_A
    Indeed, the export menu isn't visible for the Scatter matrix.
    @Marco_Boeck do you have any ideas, why the regular export could not be working?
  • Wladi
    Thank you very much @David_A for tagging Marco and thank you @Marco_Boeck for the detailed answer, i think i will find a way to present my solutions, there are a lot of possibilities  :)
    Best regards from germany and stay healthy,
    Wladi
