MS SQL database connnection
Chico
Hi there,
I'm not sure the database connection in rapidminer server is still available right now?
I was trying to create a new MS SQL connection in rapidminer server which is downloaded from aws marketplace. But the connection has failed.
After checking the iptable in the image, I couldn't find the 1433 port which MS SQL connection need it.
Any suggestions?
Kind regards,
Chico
Databases
SQL
MartinLiebig
are you talking about our AWS images? As far as i remember we ship them with a postgres, not MS SQL.
Best,
Martin
CC:
@ZSzatmari
Chico
Since I need to create a database connection to grab raw data in MS SQL server, but it looks like the port is not opened when I checked the iptables in the instance.
AMI: RapidMiner Server 9.5.3 BYOL
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy DROP)
DOCKER-USER all -- anywhere anywhere
DOCKER-ISOLATION-STAGE-1 all -- anywhere anywhere
ACCEPT all -- anywhere anywhere ctstate RELATED,ESTABLISHED
DOCKER all -- anywhere anywhere
Chain OUTPUT (policy ACCEPT)
Chain DOCKER (4 references)
ACCEPT tcp -- anywhere xxxx.compute.internal tcp dpt:https
ACCEPT tcp -- anywhere xxxx.compute.internal tcp dpt:webcache
ACCEPT tcp -- anywhere xxxx.compute.internal tcp dpt:amqp
ACCEPT tcp -- anywhere xxxx.compute.internal tcp dpt:amt-esd-prot
ACCEPT tcp -- anywhere xxxx.compute.internal tcp dpt:pvuniwien
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
DOCKER-ISOLATION-STAGE-2 all -- anywhere anywhere
RETURN all -- anywhere anywhere
Chain DOCKER-ISOLATION-STAGE-2 (4 references)
DROP all -- anywhere anywhere
Chain DOCKER-USER (1 references)
ZSzatmari
Our RapidMiner Server AWS Marketplace AMIs (images) are prepared with PostgreSQL as a RapidMiner Server database backend, but it is only for the RapidMiner Server own management data storage. You should be able to connect to any existing MS SQL server as database from any RapidMiner processes. If you have an external MS SQL database, then there is no firewall restriction on the RapidMiner Server cloud image side for any outgoing connection. If you experience any connection issues, then we propose to check your instance's networking setup in AWS (security gorup, subnet settings, IGW, etc...) and the networking/firewall setup of your MS SQL database.
