<?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Customer Data" origin="GENERATED_SAMPLE" width="90" x="45" y="136"> <parameter key="repository_entry" value="//Samples/Templates/Churn Modeling/Customer Data"/> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="set_role" compatibility="9.3.001" expanded="true" height="82" name="Set Role" origin="GENERATED_SAMPLE" width="90" x="179" y="85"> <parameter key="attribute_name" value="ChurnIndicator"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="numerical_to_binominal" compatibility="9.3.001" expanded="true" height="82" name="Numerical to Binominal" origin="GENERATED_SAMPLE" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ChurnIndicator"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="min" value="0.0"/> <parameter key="max" value="0.5"/> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="Cross Validation" origin="GENERATED_SAMPLE" width="90" x="514" y="34"> <parameter key="split_on_batch_attribute" value="false"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_folds" value="10"/> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="sample" compatibility="9.3.001" expanded="true" height="82" name="Sample" origin="GENERATED_SAMPLE" width="90" x="45" y="34"> <parameter key="sample" value="relative"/> <parameter key="balance_data" value="true"/> <parameter key="sample_size" value="100"/> <parameter key="sample_ratio" value="0.1"/> <parameter key="sample_probability" value="0.1"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"> <parameter key="true" value="1.0"/> <parameter key="false" value="0.02"/> </list> <list key="sample_probability_per_class"> <parameter key="false" value="0.02"/> <parameter key="true" value="1.0"/> </list> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.3.001" expanded="true" height="82" name="Decision Tree" origin="GENERATED_SAMPLE" width="90" x="313" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_port="training set" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <description align="left" color="yellow" colored="false" height="393" resized="false" width="217" x="10" y="10"><br> <br> <br> <br> <br> <br> <br> <br> <br> Many more customers stay than churn (hopefully!). In order for our model to learn how churners behave, we re-balance the data to focus on the case we're interested in. This is like a magnifying glass on churn!<br><br>Take a look at the 'Sample' operator.</description> <description align="left" color="green" colored="true" height="395" resized="false" width="234" x="242" y="10"><br> <br> <br> <br> <br> <br> <br> <br> <br> Let's now add a model trainer, like a Decision Tree.<br><br>Try different values for the parameters, in particular, the 'minimal gain'. The 'Wisdom of the Crowds' recommendation helps you find reasonable values.</description> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.3.001" expanded="true" height="82" name="Apply Model" origin="GENERATED_SAMPLE" width="90" x="112" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="9.3.001" expanded="true" height="82" name="Performance (Binominal Classification)" origin="GENERATED_SAMPLE" width="90" x="246" y="34"> <parameter key="manually_set_positive_class" value="false"/> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="false"/> <parameter key="AUC (pessimistic)" value="false"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="false"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="false"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (Binominal Classification)" to_port="labelled data"/> <connect from_op="Performance (Binominal Classification)" from_port="performance" to_port="performance 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> <description align="left" color="red" colored="true" height="390" resized="false" width="259" x="92" y="10"><br/><br/><br/><br/><br/><br/><br/><br/><br/>The model trained on the training data is applied to the independent test data set and the model performance is calculated.<br><br>The performance values obtained on the different folds of the cross-validation are finally averaged to produce an average performance measure as well as a measure of its dispersion - which gives an estimate of the model stability when applied to different data samples.</description> </process> </operator> </process> </code><?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve Customer Data" origin="GENERATED_SAMPLE" width="90" x="45" y="136"> <parameter key="repository_entry" value="//Samples/Templates/Churn Modeling/Customer Data"/> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="set_role" compatibility="9.3.001" expanded="true" height="82" name="Set Role" origin="GENERATED_SAMPLE" width="90" x="179" y="85"> <parameter key="attribute_name" value="ChurnIndicator"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="numerical_to_binominal" compatibility="9.3.001" expanded="true" height="82" name="Numerical to Binominal" origin="GENERATED_SAMPLE" width="90" x="313" y="85"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="ChurnIndicator"/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="numeric"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="real"/> <parameter key="block_type" value="value_series"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_series_end"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="true"/> <parameter key="min" value="0.0"/> <parameter key="max" value="0.5"/> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="multiply" compatibility="9.3.001" expanded="true" height="103" name="Multiply" width="90" x="380" y="187"/> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="split_validation" compatibility="9.3.001" expanded="true" height="124" name="Validation" width="90" x="514" y="289"> <parameter key="create_complete_model" value="false"/> <parameter key="split" value="relative"/> <parameter key="split_ratio" value="0.7"/> <parameter key="training_set_size" value="100"/> <parameter key="test_set_size" value="-1"/> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1992"/> <process expanded="true"> <operator activated="true" class="sample" compatibility="9.3.001" expanded="true" height="82" name="Sample (2)" origin="GENERATED_SAMPLE" width="90" x="45" y="34"> <parameter key="sample" value="relative"/> <parameter key="balance_data" value="true"/> <parameter key="sample_size" value="100"/> <parameter key="sample_ratio" value="0.1"/> <parameter key="sample_probability" value="0.1"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"> <parameter key="true" value="1.0"/> <parameter key="false" value="0.02"/> </list> <list key="sample_probability_per_class"> <parameter key="false" value="0.02"/> <parameter key="true" value="1.0"/> </list> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.3.001" expanded="true" height="103" name="Decision Tree (2)" origin="GENERATED_SAMPLE" width="90" x="313" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_port="training" to_op="Sample (2)" to_port="example set input"/> <connect from_op="Sample (2)" from_port="example set output" to_op="Decision Tree (2)" to_port="training set"/> <connect from_op="Decision Tree (2)" from_port="model" to_port="model"/> <portSpacing port="source_training" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.3.001" expanded="true" height="82" name="Apply Model (2)" origin="GENERATED_SAMPLE" width="90" x="112" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="9.3.001" expanded="true" height="82" name="Performance (Binominal Classification) (2)" origin="GENERATED_SAMPLE" width="90" x="246" y="34"> <parameter key="manually_set_positive_class" value="false"/> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="false"/> <parameter key="AUC (pessimistic)" value="false"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="false"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="false"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test set" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (Binominal Classification) (2)" to_port="labelled data"/> <connect from_op="Performance (Binominal Classification) (2)" from_port="performance" to_port="averagable 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_averagable 1" spacing="0"/> <portSpacing port="sink_averagable 2" spacing="0"/> </process> </operator> </process> <?xml version="1.0" encoding="UTF-8"?><process version="9.3.001"> <operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="Cross Validation" origin="GENERATED_SAMPLE" width="90" x="514" y="34"> <parameter key="split_on_batch_attribute" value="false"/> <parameter key="leave_one_out" value="false"/> <parameter key="number_of_folds" value="10"/> <parameter key="sampling_type" value="automatic"/> <parameter key="use_local_random_seed" value="true"/> <parameter key="local_random_seed" value="1992"/> <parameter key="enable_parallel_execution" value="true"/> <process expanded="true"> <operator activated="true" class="sample" compatibility="9.3.001" expanded="true" height="82" name="Sample" origin="GENERATED_SAMPLE" width="90" x="45" y="34"> <parameter key="sample" value="relative"/> <parameter key="balance_data" value="true"/> <parameter key="sample_size" value="100"/> <parameter key="sample_ratio" value="0.1"/> <parameter key="sample_probability" value="0.1"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"> <parameter key="true" value="1.0"/> <parameter key="false" value="0.02"/> </list> <list key="sample_probability_per_class"> <parameter key="false" value="0.02"/> <parameter key="true" value="1.0"/> </list> <parameter key="use_local_random_seed" value="false"/> <parameter key="local_random_seed" value="1992"/> </operator> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="9.3.001" expanded="true" height="82" name="Decision Tree" origin="GENERATED_SAMPLE" width="90" x="313" y="34"> <parameter key="criterion" value="gain_ratio"/> <parameter key="maximal_depth" value="20"/> <parameter key="apply_pruning" value="true"/> <parameter key="confidence" value="0.25"/> <parameter key="apply_prepruning" value="true"/> <parameter key="minimal_gain" value="0.1"/> <parameter key="minimal_leaf_size" value="2"/> <parameter key="minimal_size_for_split" value="4"/> <parameter key="number_of_prepruning_alternatives" value="3"/> </operator> <connect from_port="training set" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Decision Tree" to_port="training set"/> <connect from_op="Decision Tree" from_port="model" to_port="model"/> <portSpacing port="source_training set" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_through 1" spacing="0"/> <description align="left" color="yellow" colored="false" height="393" resized="false" width="217" x="10" y="10"><br> <br> <br> <br> <br> <br> <br> <br> <br> Many more customers stay than churn (hopefully!). In order for our model to learn how churners behave, we re-balance the data to focus on the case we're interested in. This is like a magnifying glass on churn!<br><br>Take a look at the 'Sample' operator.</description> <description align="left" color="green" colored="true" height="395" resized="false" width="234" x="242" y="10"><br> <br> <br> <br> <br> <br> <br> <br> <br> Let's now add a model trainer, like a Decision Tree.<br><br>Try different values for the parameters, in particular, the 'minimal gain'. The 'Wisdom of the Crowds' recommendation helps you find reasonable values.</description> </process> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="9.3.001" expanded="true" height="82" name="Apply Model" origin="GENERATED_SAMPLE" width="90" x="112" y="34"> <list key="application_parameters"/> <parameter key="create_view" value="false"/> </operator> <operator activated="true" class="performance_binominal_classification" compatibility="9.3.001" expanded="true" height="82" name="Performance (Binominal Classification)" origin="GENERATED_SAMPLE" width="90" x="246" y="34"> <parameter key="manually_set_positive_class" value="false"/> <parameter key="main_criterion" value="first"/> <parameter key="accuracy" value="true"/> <parameter key="classification_error" value="false"/> <parameter key="kappa" value="false"/> <parameter key="AUC (optimistic)" value="false"/> <parameter key="AUC" value="false"/> <parameter key="AUC (pessimistic)" value="false"/> <parameter key="precision" value="false"/> <parameter key="recall" value="false"/> <parameter key="lift" value="false"/> <parameter key="fallout" value="false"/> <parameter key="f_measure" value="false"/> <parameter key="false_positive" value="false"/> <parameter key="false_negative" value="false"/> <parameter key="true_positive" value="false"/> <parameter key="true_negative" value="false"/> <parameter key="sensitivity" value="false"/> <parameter key="specificity" value="false"/> <parameter key="youden" value="false"/> <parameter key="positive_predictive_value" value="false"/> <parameter key="negative_predictive_value" value="false"/> <parameter key="psep" value="false"/> <parameter key="skip_undefined_labels" value="true"/> <parameter key="use_example_weights" value="true"/> </operator> <connect from_port="model" to_op="Apply Model" to_port="model"/> <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance (Binominal Classification)" to_port="labelled data"/> <connect from_op="Performance (Binominal Classification)" from_port="performance" to_port="performance 1"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test set" spacing="0"/> <portSpacing port="source_through 1" spacing="0"/> <portSpacing port="sink_test set results" spacing="0"/> <portSpacing port="sink_performance 1" spacing="0"/> <portSpacing port="sink_performance 2" spacing="0"/> <description align="left" color="red" colored="true" height="390" resized="false" width="259" x="92" y="10"><br/><br/><br/><br/><br/><br/><br/><br/><br/>The model trained on the training data is applied to the independent test data set and the model performance is calculated.<br><br>The performance values obtained on the different folds of the cross-validation are finally averaged to produce an average performance measure as well as a measure of its dispersion - which gives an estimate of the model stability when applied to different data samples.</description> </process> </operator> </process> </pre><div>****This script below is for only cross validation</div><pre class="CodeBlock"><code>
