I'm extracting usernames of e-mails and I want to split these usernames according to the
separator between the first name and the last name. (the separator is different for each username).
For example here the initial dataset :
Username
john.doe
John_Doe
I want to obtain the following dataset :
Username_1 Username_2
john doe
John Doe
For this I tried to use the
Branch operator but I'm encountered an error.
Here my process :
<?xml version="1.0" encoding="UTF-8"?><process version="9.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="utility:create_exampleset" compatibility="9.3.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="112" y="85">
<parameter key="generator_type" value="comma separated text"/>
<parameter key="number_of_examples" value="100"/>
<parameter key="use_stepsize" value="false"/>
<list key="function_descriptions"/>
<parameter key="add_id_attribute" value="false"/>
<list key="numeric_series_configuration"/>
<list key="date_series_configuration"/>
<list key="date_series_configuration (interval)"/>
<parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="input_csv_text" value="Username john.doe John_Doe"/>
<parameter key="column_separator" value=","/>
<parameter key="parse_all_as_nominal" value="false"/>
<parameter key="decimal_point_character" value="."/>
<parameter key="trim_attribute_names" value="true"/>
<operator activated="true" class="multiply" compatibility="9.3.000" expanded="true" height="103" name="Multiply (2)" width="90" x="313" y="85"/>
<operator activated="true" breakpoints="before" class="branch" compatibility="9.3.000" expanded="true" height="103" name="Branch" width="90" x="514" y="85">
<parameter key="condition_type" value="expression"/>
<parameter key="condition_value" value="[Username]==john.doe"/>
<parameter key="expression" value="contains([Username],".")==TRUE"/>
<parameter key="io_object" value="ANOVAMatrix"/>
<parameter key="return_inner_output" value="true"/>
<operator activated="true" class="multiply" compatibility="9.3.000" expanded="true" height="103" name="Multiply (3)" width="90" x="45" y="238"/>
<operator activated="true" class="select_attributes" compatibility="9.3.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="238">
<parameter key="attribute" value="Username"/>
<operator activated="true" breakpoints="before" class="split" compatibility="9.3.000" expanded="true" height="82" name="Split (2)" width="90" x="179" y="136">
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="split_pattern" value="[.]"/>
<parameter key="split_mode" value="ordered_split"/>
<operator activated="true" class="union" compatibility="9.3.000" expanded="true" height="82" name="Union" width="90" x="380" y="136"/>
<connect from_port="condition" to_port="input 1"/>
<connect from_port="input 1" to_op="Multiply (3)" to_port="input"/>
<connect from_op="Multiply (3)" from_port="output 1" to_op="Split (2)" to_port="example set input"/>
<connect from_op="Multiply (3)" from_port="output 2" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Union" to_port="example set 2"/>
<connect from_op="Split (2)" from_port="example set output" to_op="Union" to_port="example set 1"/>
<connect from_op="Union" from_port="union" to_port="input 2"/>
<portSpacing port="source_condition" spacing="0"/>
<portSpacing port="sink_input 1" spacing="0"/>
<portSpacing port="sink_input 2" spacing="0"/>
<portSpacing port="sink_input 3" spacing="0"/>
</process>
<connect from_port="input 1" to_port="input 2"/>
</process>
<operator activated="true" class="branch" compatibility="9.3.000" expanded="true" height="103" name="Branch (2)" width="90" x="648" y="85">
<parameter key="condition_value" value="Username==John_doe"/>
<parameter key="expression" value="contains([Username],"_")==TRUE"/>
<operator activated="true" breakpoints="after" class="split" compatibility="9.3.000" expanded="true" height="82" name="Split" width="90" x="179" y="136">
<parameter key="split_pattern" value="[_]"/>
<connect from_port="input 1" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_port="input 2"/>
</process>
</process>
<connect from_op="Create ExampleSet" from_port="output" to_op="Multiply (2)" to_port="input"/>
<connect from_op="Multiply (2)" from_port="output 1" to_op="Branch" to_port="condition"/>
<connect from_op="Multiply (2)" from_port="output 2" to_op="Branch" to_port="input 1"/>
<connect from_op="Branch" from_port="input 1" to_op="Branch (2)" to_port="condition"/>
<connect from_op="Branch" from_port="input 2" to_op="Branch (2)" to_port="input 1"/>
<connect from_op="Branch (2)" from_port="input 2" to_port="result 1"/>
</process>
</process>
Can you help me ?
Lionel
