Pattern grouping in Optimization
arh423
arh423 Altair Community Member
Hey,
i want to optimize a wheel structure and need to use cyclic pattern grouping to get equal structures for every spoke.
But also I need a symmetry to the midplane (normal to the wheel axis).
I can't use cyclic and 1-plane pattern grouping, right?
How can I solve this?
Thank you!
Welcome!
  • Adriano Koga_20259
    Adriano Koga_20259 New Altair Community Member
    edited October 2020
    this is actually a limitation. You can't combine both symmetry into a single design space.
    But you could try this:
    - create 2 design spaces, splitting your wheel in the midplane. (1 prop for each half)
    - for one half, you will define a topology desvar (master), and cyclic symmetry
    - still in this design variable you will go to the pattern repetition, and define it as a master, picking 3 nodes defining a "reference system"
    - then, create a second topology desvar, selecting the other half, and go to the pattern repetition, picking again, 3 nodes, now, defining them as 'slave', reflected compared to the master orientation. then, reference the master design variable created previously
    This setup will force the second half to be exactly as the 1st half, per pattern repetition.
  • arh423
    edited October 2020
    Thank you!
    Is this also possible for composite optimization?
    edited October 2020
    arh423 said:
    Thank you!
    i'm not sure what is your context with composites in this case, but draw would be applicable to mostly solids structures.
Welcome!
Welcome!
