<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="-1"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.2.001" expanded="true" height="68" name="Read Excel" width="90" x="45" y="34"> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="America/New_York"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"/> <parameter key="read_not_matching_values_as_missings" value="true"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="loop_examples" compatibility="9.2.001" expanded="true" height="82" name="Loop Examples" origin="GENERATED_TUTORIAL" width="90" x="179" y="34"> <parameter key="iteration_macro" value="example"/> <process expanded="true"> <operator activated="true" class="filter_example_range" compatibility="9.2.001" expanded="true" height="82" name="Filter Example Range" width="90" x="45" y="34"> <parameter key="first_example" value="%{example}"/> <parameter key="last_example" value="%{example}"/> <parameter key="invert_filter" value="false"/> </operator> <operator activated="true" class="jdbc_connectors:write_database" compatibility="9.2.001" expanded="true" height="68" name="Write Database" width="90" x="246" y="34"> <parameter key="define_connection" value="predefined"/> <parameter key="database_system" value="MySQL"/> <parameter key="use_default_schema" value="true"/> <parameter key="overwrite_mode" value="none"/> <parameter key="set_default_varchar_length" value="false"/> <parameter key="default_varchar_length" value="128"/> <parameter key="add_generated_primary_keys" value="false"/> <parameter key="db_key_attribute_name" value="generated_primary_key"/> <parameter key="batch_size" value="1"/> </operator> <connect from_port="example set" to_op="Filter Example Range" to_port="example set input"/> <connect from_op="Filter Example Range" from_port="example set output" to_op="Write Database" to_port="input"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <connect from_op="Read Excel" from_port="output" to_op="Loop Examples" to_port="example set"/> <connect from_op="Loop Examples" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
