<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.2.000" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="UTF-8"/><br> <process expanded="true"><br> <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="45" y="34"><br> <parameter key="repository_entry" value="//Samples/data/Titanic Training"/><br> </operator><br> <operator activated="true" class="select_attributes" compatibility="9.2.000" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34"><br> <parameter key="attribute_filter_type" value="single"/><br> <parameter key="attribute" value="Survived"/><br> <parameter key="attributes" value=""/><br> <parameter key="use_except_expression" value="false"/><br> <parameter key="value_type" value="attribute_value"/><br> <parameter key="use_value_type_exception" value="false"/><br> <parameter key="except_value_type" value="time"/><br> <parameter key="block_type" value="attribute_block"/><br> <parameter key="use_block_type_exception" value="false"/><br> <parameter key="except_block_type" value="value_matrix_row_start"/><br> <parameter key="invert_selection" value="true"/><br> <parameter key="include_special_attributes" value="true"/><br> </operator><br> <operator activated="true" class="set_role" compatibility="9.2.000" expanded="true" height="82" name="Set Role" width="90" x="313" y="34"><br> <parameter key="attribute_name" value="Passenger Class"/><br> <parameter key="target_role" value="label"/><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="naive_bayes" compatibility="9.2.000" expanded="true" height="82" name="Naive Bayes" width="90" x="447" y="34"><br> <parameter key="laplace_correction" value="true"/><br> </operator><br> <operator activated="true" class="retrieve" compatibility="9.2.000" expanded="true" height="68" name="Retrieve Titanic Unlabeled" width="90" x="313" y="136"><br> <parameter key="repository_entry" value="//Samples/data/Titanic Unlabeled"/><br> </operator><br> <operator activated="true" class="set_role" compatibility="9.2.000" expanded="true" height="82" name="Set Role (2)" width="90" x="447" y="136"><br> <parameter key="attribute_name" value="Passenger Class"/><br> <parameter key="target_role" value="label"/><br> <list key="set_additional_roles"/><br> </operator><br> <operator activated="true" class="apply_model" compatibility="9.2.000" expanded="true" height="82" name="Apply Model" width="90" x="581" y="34"><br> <list key="application_parameters"/><br> <parameter key="create_view" value="false"/><br> </operator><br> <operator activated="true" class="generate_prediction_ranking" compatibility="9.2.000" expanded="true" height="82" name="Generate Prediction Ranking" width="90" x="715" y="34"><br> <parameter key="number_of_ranks" value="2"/><br> <parameter key="remove_old_predictions" value="true"/><br> </operator><br> <connect from_op="Retrieve Titanic Training" from_port="output" to_op="Select Attributes" to_port="example set input"/><br> <connect from_op="Select Attributes" from_port="example set output" to_op="Set Role" to_port="example set input"/><br> <connect from_op="Set Role" from_port="example set output" to_op="Naive Bayes" to_port="training set"/><br> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/><br> <connect from_op="Retrieve Titanic Unlabeled" from_port="output" to_op="Set Role (2)" to_port="example set input"/><br> <connect from_op="Set Role (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/><br> <connect from_op="Apply Model" from_port="labelled data" to_op="Generate Prediction Ranking" to_port="example set input"/><br> <connect from_op="Generate Prediction Ranking" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process>
