Hi Marcela,
Yes, it is possible to export OpenStreet Map maps in the .osm file format and import them into the WallMan tool within WinProp. This is done by launching the specific converte.
The steps to follow are: launch WallMan -> File -> Convert Urban database -> Vector Database -> Choose from the "format of source file" .osm and fill in the rest of the parameters -> OK.
You will be able then to use/manipulate the database as needed.
You can find a lot of helpful information in the WinProp Help: https://help.altair.com/winprop/topics/winprop/master/guide_getting_started_winprop.htm
Best Regards,
Zeina
