I can't find the logfile, I'm working on a apple PC.
But the following message I receive in de log of the bug:
- Exception: java.lang.ClassCastException
- Message: java.lang.Double cannot be cast to java.lang.String
- Stack trace:
- com.rapidminer.operator.text.Document.getNominalLabel(Document.java:244)
- com.rapidminer.operator.text.io.DocumentTextInputOperator.getLabelValues(DocumentTextInputOperator.java:43)
- com.rapidminer.operator.text.io.AbstractDocumentInputOperator.generateWordList(AbstractDocumentInputOperator.java:276)
- com.rapidminer.operator.text.io.AbstractDocumentInputOperator.doWork(AbstractDocumentInputOperator.java:155)
- com.rapidminer.operator.Operator.execute(Operator.java:1004)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
- com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:812)
- com.rapidminer.operator.ExecutionUnit$3.run(ExecutionUnit.java:807)
- java.security.AccessController.doPrivileged(Native Method)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:428)
- com.rapidminer.Process.execute(Process.java:1310)
- com.rapidminer.Process.run(Process.java:1285)
- com.rapidminer.Process.run(Process.java:1176)
- com.rapidminer.Process.run(Process.java:1129)
- com.rapidminer.Process.run(Process.java:1124)
- com.rapidminer.Process.run(Process.java:1114)
- com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
