I have a million-plus row Excel Binary (XLSB) file just under 100 MB that I am trying to add to the repository and then retrieve/load into my process as an example set.
Unfortunately... I can't get it to work.
If I convert the file to XLSX (Excel XML) file, it works fine, but the file size is larger (~300 MB). I am writing an Excel file at the end of my process, so I need to open that up and convert back to XLSB anyway but I was just curious what I should be doing to retrieve this binary file.
Is the XLSB file format not fully supported?
