If a variable is already coded as a dummy, then, after importing the dataset to the design interface, should I set the type as integer or binominal (and then transform from nominal to numeric)?
Also, if the variable is ordinal should it be set as polynominal or integer? What if it is ordinal but the values are not 'complete' e.g. 1,2,3,4,8?
