Hi
For some reason my code becomes corrupt when pasting, so I have included as much info as possible to try and help with this issue:
A screenshot of the process below shows how the data is generates, and id attribute is then added, the data is filtered to take the first row out. The Select Attribute process is used to deslect the ID attribute, the Remove Attribute is used to further try and take out the id that has been generated.
However in the output fields the id attribute is still present.
How do I effectivly remove the id attribute from the final output?
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<operator activated="true" class="generate_data" compatibility="7.6.001" expanded="true" height="68" name="Generate Data" width="90" x="447" y="187">
<parameter key="target_function" value="random"/>
<parameter key="number_examples" value="100"/>
<parameter key="number_of_attributes" value="5"/>
<parameter key="attributes_lower_bound" value="-10.0"/>
<parameter key="attributes_upper_bound" value="10.0"/>
<parameter key="gaussian_standard_deviation" value="10.0"/>
<parameter key="largest_radius" value="10.0"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</process>
<operator activated="true" class="generate_id" compatibility="7.6.001" expanded="true" height="82" name="Generate ID" width="90" x="581" y="187">
<parameter key="create_nominal_ids" value="false"/>
<parameter key="offset" value="0"/>
</process>
<operator activated="true" class="filter_example_range" compatibility="7.6.001" expanded="true" height="82" name="Filter Example Range" width="90" x="715" y="187">
<parameter key="first_example" value="1"/>
<parameter key="last_example" value="1"/>
<parameter key="invert_filter" value="false"/>
</process>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes" width="90" x="1050" y="340">
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value="requests"/>
</process>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="849" y="136">
<parameter key="attributes" value="label|att5|att4|att3|att2|att1"/>
</process>
<operator activated="true" class="remove_attribute_range" compatibility="7.6.001" expanded="true" height="82" name="Remove Attribute Range" width="90" x="1050" y="136">
<parameter key="first_attribute" value="1"/>
<parameter key="last_attribute" value="1"/>
</process>
