Hi all,
my process outputs JSON with the Data to JSON from the Text Processing Extension/Plugin.
I want to cast the output ioResult.getElementAt(0) to this com.rapidminer.operator.text.Document so I can access the JSON string.
I can't perform that cast because the class is not known. I don't have the jar files apparently (Intellij can't find it).
What gradle dependencies should be added so I can access code that is added as an extension/plugin to Rapidminer Studio?
Or is there another solution to this problem?
Kind regards,
Wouter
