Dear All,
I am using a log file on on a cross validation inside an Optimize Parameters function. The cross validation run on a kNN model with performance measured by a performance (regression) function. When I use the log file to view my performance measures (absolute_error and relative_error) for each iteration the values returned is a ?.
In the log file I have selected Absoluter Error - Performance - value - Absolute Error
Thank you in advance for your help
Below is the XML Code (I think)
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="concurrency:cross_validation" compatibility="7.5.001" expanded="true" height="145" name="Cross Validation" width="90" x="380" y="85">
<operator activated="true" class="k_nn" compatibility="7.5.001" expanded="true" height="82" name="k-NN (2)" width="90" x="179" y="34">
<parameter key="k" value="2"/>
<connect from_port="training set" to_op="k-NN (2)" to_port="training set"/>
<connect from_op="k-NN (2)" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.5.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<operator activated="true" class="performance" compatibility="7.5.001" expanded="true" height="82" name="Performance" width="90" x="313" y="187"/>
<operator activated="true" class="extract_performance" compatibility="7.5.001" expanded="true" height="82" name="Performance (2)" width="90" x="246" y="34"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_op="Performance (2)" to_port="example set"/>
<connect from_op="Performance" from_port="performance" to_port="performance 1"/>
<connect from_op="Performance" from_port="example set" to_port="test set results"/>
<portSpacing port="sink_test set results" spacing="0"/>
<portSpacing port="sink_performance 1" spacing="0"/>
<portSpacing port="sink_performance 2" spacing="0"/>
</process>
<connect from_op="Cross Validation" from_port="model" to_port="result 1"/>
<connect from_op="Cross Validation" from_port="example set" to_port="result 2"/>
<connect from_op="Cross Validation" from_port="test result set" to_port="result 3"/>
<connect from_op="Cross Validation" from_port="performance 1" to_port="result 4"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</process>
