Hi...anyone having trouble using the Weka models (e.g. W-J48) with the Model Management extension? I tried to use two models to compare (Decision Tree and W-J48) and it did NOT like it.
Scott
I haven't tried it but maybe ping @bhupendra_patil? I think he was a key author for this extension.
Scott,
i've tried to reproduce it. I can add a J48 into the collection. There is some issue with the meta data, but it runs smoothly. Can you explain a bit more what your issue is?
Best,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="7.5.001" expanded="true" height="68" name="Retrieve Golf" width="90" x="45" y="85"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="multiply" compatibility="7.5.001" expanded="true" height="124" name="Multiply" width="90" x="179" y="85"/> <operator activated="true" class="weka:W-J48" compatibility="7.3.001-SNAPSHOT" expanded="true" height="82" name="W-J48" width="90" x="380" y="34"/> <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="7.5.001" expanded="true" height="82" name="Decision Tree" width="90" x="380" y="238"/> <operator activated="true" class="h2o:deep_learning" compatibility="7.2.000" expanded="true" height="82" name="Deep Learning" width="90" x="380" y="136"> <enumeration key="hidden_layer_sizes"> <parameter key="hidden_layer_sizes" value="50"/> <parameter key="hidden_layer_sizes" value="50"/> </enumeration> <enumeration key="hidden_dropout_ratios"/> <list key="expert_parameters"/> <list key="expert_parameters_"/> </operator> <operator activated="false" class="k_nn" compatibility="7.5.001" expanded="true" height="82" name="k-NN" width="90" x="112" y="340"/> <operator activated="true" class="retrieve" compatibility="7.5.001" expanded="true" height="68" name="Retrieve Golf-Testset (2)" width="90" x="648" y="493"> <parameter key="repository_entry" value="//Samples/data/Golf-Testset"/> <description align="center" color="transparent" colored="false" width="126">This is our test dataset to compare models</description> </operator> <operator activated="true" class="collect" compatibility="7.5.001" expanded="true" height="124" name="Collect" width="90" x="648" y="34"> <description align="center" color="transparent" colored="false" width="126">We will create a collection of models to test</description> </operator> <operator activated="true" class="model_management:model_management_key" compatibility="7.3.000" expanded="true" height="103" name="Compare Models" width="90" x="849" y="136"> <parameter key="folder" value="//Local Repository/Model Management/Project 1"/> <parameter key="date_format" value="yyyy_MM_dd_HH_mm"/> <process expanded="true"> <operator activated="true" class="apply_model" compatibility="7.5.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="447" y="136"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance" compatibility="7.5.001" expanded="true" height="82" name="Performance (2)" width="90" x="715" y="34"/> <connect from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_port="test data" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_op="Performance (2)" to_port="labelled data"/> <connect from_op="Apply Model (2)" from_port="model" to_port="model"/> <connect from_op="Performance (2)" from_port="performance" to_port="performance"/> <portSpacing port="source_model" spacing="0"/> <portSpacing port="source_test data" spacing="0"/> <portSpacing port="source_in 1" spacing="0"/> <portSpacing port="sink_performance" spacing="0"/> <portSpacing port="sink_model" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> </process> </operator> <connect from_op="Retrieve Golf" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="W-J48" to_port="training set"/> <connect from_op="Multiply" from_port="output 2" to_op="Deep Learning" to_port="training set"/> <connect from_op="Multiply" from_port="output 3" to_op="Decision Tree" to_port="training set"/> <connect from_op="W-J48" from_port="model" to_op="Collect" to_port="input 1"/> <connect from_op="Decision Tree" from_port="model" to_op="Collect" to_port="input 3"/> <connect from_op="Deep Learning" from_port="model" to_op="Collect" to_port="input 2"/> <connect from_op="Retrieve Golf-Testset (2)" from_port="output" to_op="Compare Models" to_port="test data"/> <connect from_op="Collect" from_port="collection" to_op="Compare Models" to_port="model collection"/> <connect from_op="Compare Models" from_port="performance" to_port="result 1"/> <connect from_op="Compare Models" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <description align="center" color="yellow" colored="false" height="138" resized="false" width="180" x="335" y="336">We are going to build three different models here.<br/><br/>You can also attach models from Repository if you wish to compare them against the three models built here</description> </process> </operator></process>
