Problem with extensional Operator "Get Pages"
I have a problem with the Operator "Get Pages" from Web Mining Extension.
It seems like that the operator is having a coding problem with UTF-8 charakters such aus "Ü".
With Mozilla Firefox I get a json-response with results after calling the URL "https://itunes.apple.com/search?term="Google Übersetzer"&entity=software&country=de&media=software&limit=5".
By calling this URL via Operator "Get Pages" I get a json-result but without an search-result.
Thats my test-process:
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.5.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="generate_data" compatibility="7.5.001" expanded="true" height="68" name="Generate Data" width="90" x="45" y="34">
<parameter key="target_function" value="random"/>
<parameter key="number_examples" value="1"/>
<parameter key="number_of_attributes" value="1"/>
<parameter key="attributes_lower_bound" value="-10.0"/>
<parameter key="attributes_upper_bound" value="10.0"/>
<parameter key="gaussian_standard_deviation" value="10.0"/>
<parameter key="largest_radius" value="10.0"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="generate_attributes" compatibility="7.5.001" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="34">
<parameter key="att1" value=""https://itunes.apple.com/search?term=\"Google Übersetzer\"&entity=software&country=de&media=software&limit=5""/>
</list>
<parameter key="keep_all" value="true"/>
<operator activated="true" class="web:retrieve_webpages" compatibility="7.3.000" expanded="true" height="68" name="getPage" width="90" x="313" y="34">
<parameter key="link_attribute" value="att1"/>
<parameter key="page_attribute" value="html"/>
<parameter key="random_user_agent" value="false"/>
<parameter key="user_agent" value="Mozilla/5.0 (Windows NT 10.0; WOW64; rv:52.0) Gecko/20100101 Firefox/52.0"/>
<parameter key="connection_timeout" value="2000"/>
<parameter key="read_timeout" value="2000"/>
<parameter key="follow_redirects" value="true"/>
<parameter key="accept_cookies" value="none"/>
<parameter key="cookie_scope" value="global"/>
<parameter key="request_method" value="POST"/>
<parameter key="delay" value="random"/>
<parameter key="delay_amount" value="5000"/>
<parameter key="min_delay_amount" value="2000"/>
<parameter key="max_delay_amount" value="5000"/>
<connect from_op="Generate Data" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="getPage" to_port="Example Set"/>
<connect from_op="getPage" from_port="Example Set" to_port="result 1"/>
</process>
</process>
Can you reproduce the issue and do you think that this is a bug of the operator or do I have to escape the url and if yes in which way?
Regards
Johannes
