I tried in differnt ways to cut a a string or digit from right side but i m unable to get.
For example I have a column A. I need five digits like column B. Please help me out
doesn't the suffix function in Generate Attributes do the job?
~Martin
Exactly as @mschmitz said above, but you might need to convert your integer on the left column into a nominal value first using str() or one of the RapidMiner operators.
Here is a sample process.
<?xml version="1.0" encoding="UTF-8"?><process version="7.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="7.3.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="text:create_document" compatibility="7.3.000" expanded="true" height="68" name="Create Document" width="90" x="45" y="136"> <parameter key="text" value="220170002 857203 88986401 96600"/> </operator> <operator activated="true" class="text:write_document" compatibility="7.3.000" expanded="true" height="82" name="Write Document" width="90" x="179" y="136"/> <operator activated="true" class="read_csv" compatibility="7.3.000" expanded="true" height="68" name="Read CSV" width="90" x="313" y="136"> <parameter key="first_row_as_names" value="false"/> <list key="annotations"/> <list key="data_set_meta_data_information"/> </operator> <operator activated="true" class="generate_attributes" compatibility="7.3.000" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="136"> <list key="function_descriptions"> <parameter key="suffix_example" value="suffix(str(att1),5)"/> </list> <description align="center" color="transparent" colored="false" width="126">Note the use of str() to change the integer value into a nominal value before suffix.</description> </operator> <connect from_op="Create Document" from_port="output" to_op="Write Document" to_port="document"/> <connect from_op="Write Document" from_port="file" to_op="Read CSV" to_port="file"/> <connect from_op="Read CSV" from_port="output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
