Hello.
I have troubles to use Read XML Operator.
I read this xml file:
<ROOT>
<RECORD>
<ID>id1</ID>
<TEXT name="text1">
<KEYWORD>kw1</KEYWORD>
<KEYWORD>kw2</KEYWORD>
<KEYWORD>kw3</KEYWORD>
</TEXT>
</RECORD>
<RECORD>
<ID>ID2</ID>
<TEXT name="text2">
<KEYWORD>kw4</KEYWORD>
<KEYWORD>kw5</KEYWORD>
<KEYWORD>kw6</KEYWORD>
</TEXT>
</RECORD>
</ROOT>
and want to get this table:
| ID |
name |
KEYWORD |
| id1 |
text1 |
kw1 |
| id1 |
text1 |
kw2 |
| id1 |
text1 |
kw3 |
| ID2 |
text2 |
kw4 |
| ID2 |
text2 |
kw5 |
| ID2 |
text2 |
kw6 |
How I can do it?
Xml version of process is here:
<?xml version="1.0" encoding="UTF-8"?><process version="7.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="advanced_file_connectors:read_xml" compatibility="7.2.003" expanded="true" height="68" name="Read XML (2)" width="90" x="45" y="136">
<parameter key="file" value="D:\1\new 4.xml"/>
<parameter key="xpath_for_examples" value="//ROOT/RECORD"/>
<enumeration key="xpaths_for_attributes">
<parameter key="xpath_for_attribute" value="TEXT[1]/attribute::name"/>
<parameter key="xpath_for_attribute" value="TEXT[1]/KEYWORD[1]/text()"/>
</enumeration>
<list key="namespaces"/>
<parameter key="use_default_namespace" value="false"/>
<list key="annotations"/>
<parameter key="0" value="TEXT[1]/attribute::name.true.attribute_value.attribute"/>
<parameter key="1" value="TEXT[1]/KEYWORD[1]/text().true.attribute_value.attribute"/>
</list>
<operator activated="true" class="advanced_file_connectors:read_xml" compatibility="7.2.003" expanded="true" height="68" name="Read XML" width="90" x="45" y="34">
<parameter key="xpath_for_attribute" value="ID[1]/text()"/>
</enumeration>
<parameter key="0" value="ID[1]/text().true.attribute_value.attribute"/>
<parameter key="1" value="TEXT[1]/attribute::name.true.attribute_value.attribute"/>
</list>
<operator activated="true" class="join" compatibility="7.2.003" expanded="true" height="82" name="Join" width="90" x="313" y="34">
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="TEXT[1]/attribute::name" value="TEXT[1]/attribute::name"/>
</list>
<connect from_op="Read XML (2)" from_port="output" to_op="Join" to_port="right"/>
<connect from_op="Read XML" from_port="output" to_op="Join" to_port="left"/>
<connect from_op="Join" from_port="join" to_port="result 1"/>
</process>
</process>
