I have just started out with RapidMiner. I have a scenario where my input is list of tokens(only one field) saved in an Excel A. Next step is to extract the whole cell content from Excel B if there is a match.In addition to this, the corresponding fields fields from Excel B also should be displayed.I tried using process documents and cut document operators but couldn't proceed further.Any help woud be appreciated.
Ex: Column Token has value "test" in Excel A
Excel B -Column Desc: "This test is a good test" , Status: Good, Priority: Critical
Column Desc: "This is good" , Status: Good, Priority: Critical
After applying Text processing, it should print the following
"This test is a good test" Good Critical
