I am using the replace dictionary operator to standardize some domain values within my data set. However, is there a way to also get the original value and the changed value as an output??
Thanks!
Hi amotley,
you can simply you the original data back on the resulting table.
~Martin
If I am understanding this well then, What I can suggest is duplicate the original column first, and then do you replace etc on one of those two columns
You can use the "generate copy" operator which makes a copy or a "generate attributes" to create a duplicate column where the expression will be just the column you want to duplicate.
let us know if we misunderstood the question
