Hello.
You can use contour control handle to set up the result type and other settings of the result from result control handle .After that you should use modle handle to show the elements or components you want to display on the screen.
https://community.altair.com/community?id=community_question&sys_id=8ead45ff1b93c950c4dfdbd9dc4bcb1c
Hello. You can use contour control handle to set up the result type and other settings of the result from result control handle .After that you should use modle handle to show the elements or components you want to display on the screen.
Thank you so much @Nagahashi Kouta . This helped
I found the solution myself.
It is elem_set add 'component_name = steel'
