<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="6.4.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.4.000" expanded="true" name="Process"> <process expanded="true"> <operator activated="true" class="generate_data" compatibility="6.4.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="165"> <parameter key="target_function" value="non linear"/> </operator> <operator activated="true" class="select_attributes" compatibility="6.4.000" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="label"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="discretize_by_bins" compatibility="6.4.000" expanded="true" height="94" name="Discretize (2)" width="90" x="313" y="165"> <parameter key="number_of_bins" value="5"/> <parameter key="range_name_type" value="short"/> </operator> <operator activated="true" class="loop_attributes" compatibility="6.4.000" expanded="true" height="94" name="Loop Attributes" width="90" x="447" y="165"> <process expanded="true"> <operator activated="true" class="multiply" compatibility="6.4.000" expanded="true" height="94" name="Multiply" width="90" x="11" y="52"/> <operator activated="true" class="set_role" compatibility="6.4.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="210"> <parameter key="attribute_name" value="%{loop_attribute}"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="weight_by_gini_index" compatibility="6.4.000" expanded="true" height="76" name="Weight by Gini Index" width="90" x="313" y="210"/> <operator activated="true" class="weights_to_data" compatibility="6.4.000" expanded="true" height="60" name="Weights to Data" width="90" x="447" y="210"/> <operator activated="true" class="generate_attributes" compatibility="6.4.000" expanded="true" height="76" name="Generate Attributes" width="90" x="581" y="210"> <list key="function_descriptions"> <parameter key="Iteration" value=""%{loop_attribute}""/> </list> </operator> <operator activated="true" class="order_attributes" compatibility="6.4.000" expanded="true" height="76" name="Reorder Attributes" width="90" x="715" y="210"> <parameter key="attribute_ordering" value="Iteration|Attribute|Weight"/> </operator> <connect from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Weight by Gini Index" to_port="example set"/> <connect from_op="Weight by Gini Index" from_port="weights" to_op="Weights to Data" to_port="attribute weights"/> <connect from_op="Weights to Data" from_port="example set" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_op="Reorder Attributes" to_port="example set input"/> <connect from_op="Reorder Attributes" from_port="example set output" to_port="result 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_example set" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <description align="center" color="yellow" colored="false" height="193" resized="true" width="283" x="153" y="129">Weight by Gini Index always calcs the Index for the label. Same stuff works with information Gain etc.</description> <description align="center" color="yellow" colored="false" height="189" resized="true" width="412" x="441" y="133">Transform it a bit to make it easier readable</description> </process> <description align="center" color="transparent" colored="false" width="126">Loop so that each attribute is label once</description> </operator> <operator activated="true" class="append" compatibility="6.4.000" expanded="true" height="76" name="Append" width="90" x="581" y="210"/> <connect from_op="Generate Data" from_port="output" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Discretize (2)" to_port="example set input"/> <connect from_op="Discretize (2)" from_port="example set output" to_op="Loop Attributes" to_port="example set"/> <connect from_op="Loop Attributes" from_port="example set" to_port="result 1"/> <connect from_op="Loop Attributes" from_port="result 1" to_op="Append" to_port="example set 1"/> <connect from_op="Append" from_port="merged set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <description align="center" color="yellow" colored="false" height="249" resized="true" width="394" x="23" y="101">Get some polynomal data</description> </process> </operator></process>
