I'm running into execution problems with the process below; without parallel enabled on the process it takes 1min 27sec to complete.
the process has 7.73Million examples and 26 attributes.
If I enable parallel on the process the application crashes frequently.
I thought that by enabling the parallel option on the process and subprocesses that this would help processing in cases like this?
Are there recommendations for the configuration of number of thread parameters?
preferences - miscellaneous Max no of threads = 0?
preferences - paralel - Number of threads = 4?
these values are both defaulted.
are there guidelines on the usage of these parameters? / values that should not be set?
is it possible to increase these values to get better process execution times?
I'd appreciate any feedback / other user experience
Kind regards,
Daryl.
system:
Macbook pro
dual core i7 3Ghz processor
8GB 1600Mhz DDR3 memory
SSD
Rapidminer studio pro 6.3 license (8GB ram).
<process version="6.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.3.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="Get AWOR Dataset" width="90" x="45" y="30">
<description>get the Adverse weather outage dataset</description>
<parameter key="repository_entry" value="../../Data_V4/AWOR/AWOR_Cooked-Dataset-V4"/>
<operator activated="true" class="replace" compatibility="6.3.000" expanded="true" height="76" name="Replace" width="90" x="179" y="30">
<parameter key="attribute" value="OutageCountyid"/>
<parameter key="replace_what" value="NL"/>
<parameter key="replace_by" value="DL"/>
<operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="Get hly2075 dataset" width="90" x="45" y="165">
<description>get the donegal hourly dataset</description>
<parameter key="repository_entry" value="../../Data_V4/HourlyA/hly2075"/>
<operator activated="true" class="retrieve" compatibility="6.3.000" expanded="true" height="60" name="ReGet SynopticStationsByCounty-V2" width="90" x="45" y="255">
<description>get the synopitc station dataset</description>
<parameter key="repository_entry" value="../../Data_V4/CountyLocations/SynopticStationsByCounty-V4"/>
<operator activated="true" class="subprocess" compatibility="6.3.000" expanded="true" height="112" name="Merge Datasets" width="90" x="246" y="165">
<operator activated="true" class="join" compatibility="6.3.000" expanded="true" height="76" name="Hly + county" width="90" x="45" y="120">
<description>Join the hourly donegal meterlogolocal information with the synoptic station information necessary to make the forecast
</description>
<parameter key="join_type" value="left"/>
<parameter key="use_id_attribute_as_key" value="false"/>
<list key="key_attributes">
<parameter key="StationName" value="SStationName"/>
</list>
<operator activated="true" class="join" compatibility="6.3.000" expanded="true" height="76" name="AWOR + hly'" width="90" x="179" y="30">
<description>Join the AWOR dataset with the result of the data merger of the donegal hourly with the synoptic station data</description>
<parameter key="OutageCountyid" value="SSCountyid"/>
</list>
<connect from_port="in 1" to_op="AWOR + hly'" to_port="left"/>
<connect from_port="in 2" to_op="Hly + county" to_port="left"/>
<connect from_port="in 3" to_op="Hly + county" to_port="right"/>
<connect from_op="Hly + county" from_port="join" to_op="AWOR + hly'" to_port="right"/>
<connect from_op="AWOR + hly'" from_port="join" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="72"/>
<portSpacing port="source_in 3" spacing="0"/>
<portSpacing port="source_in 4" spacing="54"/>
</process>
<operator activated="true" class="subprocess" compatibility="6.3.000" expanded="true" height="76" name="Make Forecast" width="90" x="380" y="120">
<description>Make a forecast</description>
<operator activated="true" class="generate_attributes" compatibility="6.3.000" expanded="true" height="76" name="Create Forecast" width="90" x="45" y="30">
<description>create the forecast
using the followign regular expression:
"if(OutageHour==DateUTC,"OutageForecasted","NoOutageForecasted")"</description>
<parameter key="ForecastedOutageHour" value="if(OutageHour==DateUTC,"OutageForecasted","NoOutageForecasted")"/>
</list>
<operator activated="true" class="set_role" compatibility="6.3.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="30">
<description>make the forecast attribute as spectial type 'label'</description>
<parameter key="attribute_name" value="ForecastedOutageHour"/>
<operator activated="true" class="generate_id" compatibility="6.3.000" expanded="true" height="76" name="Generate ID" width="90" x="45" y="210">
<description>create an id for the forecast</description>
<operator activated="true" class="rename" compatibility="6.3.000" expanded="true" height="76" name="Rename id" width="90" x="179" y="210">
<parameter key="old_name" value="id"/>
<parameter key="new_name" value="ForecastID"/>
<list key="rename_additional_attributes"/>
<connect from_port="in 1" to_op="Create Forecast" to_port="example set input"/>
<connect from_op="Create Forecast" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Rename id" to_port="example set input"/>
<connect from_op="Rename id" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 1" spacing="180"/>
</process>
<operator activated="true" class="store" compatibility="6.3.000" expanded="true" height="60" name="st forecast" width="90" x="514" y="120">
<description>store the donegal forecast</description>
<parameter key="repository_entry" value="../../Data_V4/Forecast/CookedHlyForecast_DS-stn2075-V4a"/>
<connect from_op="Get AWOR Dataset" from_port="output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Merge Datasets" to_port="in 1"/>
<connect from_op="Get hly2075 dataset" from_port="output" to_op="Merge Datasets" to_port="in 2"/>
<connect from_op="ReGet SynopticStationsByCounty-V2" from_port="output" to_op="Merge Datasets" to_port="in 3"/>
<connect from_op="Merge Datasets" from_port="out 1" to_op="Make Forecast" to_port="in 1"/>
<connect from_op="Make Forecast" from_port="out 1" to_op="st forecast" to_port="input"/>
<connect from_op="st forecast" from_port="through" to_port="result 1"/>
<portSpacing port="sink_result 1" spacing="90"/>
</process>
</process>
