Hi all,
I am confused about the operator "loop repository".
I have a bundle of data set with the same format, I want use the "loop repository" to deal with all the data sets.
I made a small example: I want to "retrieve" all the data set in my folder. How can I do that?
<process version="6.1.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.1.000" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="loop_repository" compatibility="6.1.000" expanded="true" height="76" name="Loop Repository" width="90" x="246" y="255">
<parameter key="repository_folder" value="../data/sepData/"/>
<operator activated="true" class="retrieve" compatibility="6.1.000" expanded="true" height="60" name="Retrieve" width="90" x="313" y="255">
<parameter key="repository_entry" value="%{repository_path}%{entry_name}"/>
<connect from_op="Retrieve" from_port="output" to_port="out 1"/>
<portSpacing port="source_repository object" spacing="0"/>
</process>
<connect from_op="Loop Repository" from_port="out 1" to_port="result 1"/>
</process>
</process>
Thanks!
