Hey there,
my task is to predict frequency spectra from two different measurements. I measure with 3 sensors, so each measurement has 3 entries as columns.
A was measured under an different environment than B.
The data have the following shape:
Measurement A:
Measurement B:
The thesis is that I can use a stochastic approach to predict B using A. So I make a measurement C under the same conditions as A and want to use RM to predict D (which will have the same environment as
I hope you understand what I want to try.
The question is now how I can realize this with RM. I already thought Multi Label is the answer, but apparently I misunderstood what it does.
Is it even possible to create D with its three column? Do you have any advice?
Thanks in advance!
Doninhas
