is there a chance to export the tetra elements check on a txt file or other ?
you mean the element verification results or the node coordinates?
Yes there is available function to check and save as text file but i don't remember where it is. Could you look for utility tab>QA ? Tomorrow i will search it...
I want to konw if there is a possibility to have a summary in a txt fle or other, where there are listed the results of element verifcation (like for 2D elems).
I don't see a similar macro for 3d elements.
You can refer to ../altair/hm/scripts/2DElemQReport.tcl to write a script for 3d
