Hi all, In hypermesh, is there any option to select only the visible Surfaces , similar to the selection of visible elements? (Don't confuse with displayed option).
you want to select only surface available on screen or want to pick only specific surfaces.
I believe Extended entity selection menu should work for any complex case.See attached screenshot.
Any surface panel would give you freedom to open extended entity selection menu.For example under automesh panel you can select this via extended entity selection or if you want to pick only unmeshed surfaces then click on unmeshed.
