I am having a hard time with the recall operator and I would appreciate it a lot if anyone could help me.
I want to use the same train and test data sets in different X-validations,
so I store the data sets with two distinct remember operators (one for training data sets and the other
for testing data sets) on the first X-Validation which is executed before the others.
When I try to retrieve the aforementioned data sets on the next X-Validations with the recall operators (a different one
for the training and testing of X-Validation) I get the train data sets on both occasions.
I pasted below the XML code .
First the recall operators:
<operator activated="true" class="remember" compatibility="5.3.006" expanded="true" height="60" name="Remember" width="90" x="45" y="255">
<parameter key="name" value="train%{a}"/>
<parameter key="io_object" value="ExampleSet"/>
<operator activated="true" class="remember" compatibility="5.3.006" expanded="true" height="60" name="Remember (2)" width="90" x="45" y="210">
<parameter key="name" value="test%{a}"/>
Below the recall code (the %{ll2} is a macro) :
<operator activated="true" class="generate_macro" compatibility="5.3.006" expanded="true" height="76" name="Generate Macro" width="90" x="45" y="30">
<parameter key="ll" value="param("Validation Knn","number_of_validations")"/>
</list>
<operator activated="true" class="generate_macro" compatibility="5.3.006" expanded="true" height="76" name="Generate Macro (2)" width="90" x="179" y="30">
<parameter key="ll2" value="(%{a})%(floor(%{ll}))+1"/>
</list>
<operator activated="true" class="recall" compatibility="5.3.006" expanded="true" height="60" name="Recall" width="90" x="179" y="120">
<parameter key="name" value="train%{ll2}"/>
<parameter key="remove_from_store" value="false"/>
<operator activated="true" class="recall" compatibility="5.3.006" expanded="true" height="60" name="Recall (2)" width="90" x="45" y="165">
<parameter key="name" value="test%{ll2}"/>
