Hello everybody,
I try to use the standard neural net operator to solve a classification problem with nominal attributs. To test whether this operator works properly I connected the labeled data to the neural net operator und the same data unlabeled to the apply model operator. Before I use the nominal to numerical modification operator to bring the soucedata in the corresponding form.
Here is an example of the labeled data:
ID Value Label
1 J no
2 G no
3 B no
4 E no
5 E no
6 J no
7 A no
8 D no
9 H yes
10 J no
11 F no
12 H yes
13 A no
14 C no
15 G no
16 D no
17 H yes
18 G no
19 J no
As you can see the attribut "H" is labeled with "yes", all other attributs with "no".
I apply the trained neural net on this data:
ID Value
1 J
2 G
3 B
4 E
5 E
6 J
7 A
8 D
9 H
10 J
11 F
12 H
13 A
14 C
15 G
16 D
17 H
18 G
19 J
The result is, that the attribute "F" is predicted as "yes" and the rest with "no". So I imply that this operater does work, but not in the right way.
Can anybody help me? What am I doing wrong?
<process version="5.3.000">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process">
<process expanded="true" height="404" width="815">
<operator activated="true" class="read_excel" compatibility="5.3.000" expanded="true" height="60" name="Read Excel" width="90" x="112" y="75">
<parameter key="excel_file" value="C:\Users\knolljli\Desktop\testdata.xlsx"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1:C730"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="German"/>
<parameter key="0" value="ID.true.integer.id"/>
<parameter key="1" value="Value.true.polynominal.attribute"/>
<parameter key="2" value="Label.true.binominal.label"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<operator activated="true" class="nominal_to_numerical" compatibility="5.3.000" expanded="true" height="94" name="Nominal to Numerical" width="90" x="313" y="75">
<parameter key="return_preprocessing_model" value="false"/>
<parameter key="create_view" value="false"/>
<parameter key="attribute_filter_type" value="all"/>
<parameter key="attribute" value=""/>
<parameter key="value_type" value="nominal"/>
<parameter key="except_value_type" value="file_path"/>
<parameter key="block_type" value="single_value"/>
<parameter key="except_block_type" value="single_value"/>
<parameter key="coding_type" value="dummy coding"/>
<parameter key="use_comparison_groups" value="false"/>
<list key="comparison_groups"/>
<parameter key="unexpected_value_handling" value="all 0 and warning"/>
<parameter key="use_underscore_in_name" value="false"/>
<operator activated="true" class="neural_net" compatibility="5.3.000" expanded="true" height="76" name="Neural Net" width="90" x="514" y="75">
<list key="hidden_layers"/>
<parameter key="training_cycles" value="500"/>
<parameter key="learning_rate" value="0.3"/>
<parameter key="momentum" value="0.2"/>
<parameter key="decay" value="false"/>
<parameter key="shuffle" value="true"/>
<parameter key="normalize" value="true"/>
<parameter key="error_epsilon" value="1.0E-5"/>
<parameter key="use_local_random_seed" value="false"/>
<parameter key="local_random_seed" value="1992"/>
<operator activated="true" class="read_excel" compatibility="5.3.000" expanded="true" height="60" name="Read Excel (2)" width="90" x="112" y="255">
<parameter key="imported_cell_range" value="A1:B730"/>
</list>
</list>
<operator activated="true" class="nominal_to_numerical" compatibility="5.3.000" expanded="true" height="94" name="Nominal to Numerical (2)" width="90" x="313" y="255">
<operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="715" y="120">
<connect from_port="input 1" to_op="Read Excel" to_port="file"/>
<connect from_port="input 2" to_op="Read Excel (2)" to_port="file"/>
<connect from_op="Read Excel" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/>
<connect from_op="Nominal to Numerical" from_port="example set output" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_op="Read Excel (2)" from_port="output" to_op="Nominal to Numerical (2)" to_port="example set input"/>
<connect from_op="Nominal to Numerical (2)" from_port="example set output" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
<portSpacing port="source_input 3" spacing="0"/>
</process>
</process>
