<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="251" width="882"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="112" y="120"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log" width="90" x="246" y="120"> <list key="log"> <parameter key="repositoryEntry" value="operator.Retrieve.parameter.repository_entry"/> </list> </operator> <operator activated="true" class="log_to_data" compatibility="5.2.008" expanded="true" height="94" name="Log to Data" width="90" x="380" y="120"/> <operator activated="true" class="extract_macro" compatibility="5.2.008" expanded="true" height="60" name="Extract Macro" width="90" x="514" y="120"> <parameter key="macro" value="reMacro"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="repositoryEntry"/> <parameter key="example_index" value="1"/> </operator> <operator activated="true" class="provide_macro_as_log_value" compatibility="5.2.008" expanded="true" height="76" name="Provide Macro as Log Value" width="90" x="648" y="120"> <parameter key="macro_name" value="reMacro"/> </operator> <operator activated="true" class="log" compatibility="5.2.008" expanded="true" height="76" name="Log (2)" width="90" x="782" y="120"> <list key="log"> <parameter key="reMacro" value="operator.Provide Macro as Log Value.value.macro_value"/> </list> </operator> <connect from_op="Retrieve" from_port="output" to_op="Log" to_port="through 1"/> <connect from_op="Log" from_port="through 1" to_op="Log to Data" to_port="through 1"/> <connect from_op="Log to Data" from_port="exampleSet" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Provide Macro as Log Value" to_port="through 1"/> <connect from_op="Provide Macro as Log Value" from_port="through 1" to_op="Log (2)" to_port="through 1"/> <connect from_op="Log (2)" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
