<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="341" width="547"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="30"> <parameter key="number_examples" value="10"/> <parameter key="number_of_attributes" value="450"/> </operator> <operator activated="true" class="remember" compatibility="5.3.000" expanded="true" height="60" name="Remember" width="90" x="179" y="30"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="read_database" compatibility="5.3.000" expanded="true" height="60" name="Read Database" width="90" x="45" y="120"> <parameter key="connection" value="GezondeKas"/> <parameter key="query" value="SHOW COLUMNS FROM WeeklyAggregatedValue;"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="extract_macro" compatibility="5.3.000" expanded="true" height="60" name="Extract Macro" width="90" x="179" y="120"> <parameter key="macro" value="attributeCount"/> <list key="additional_macros"/> </operator> <operator activated="true" class="loop" compatibility="5.3.000" expanded="true" height="76" name="Loop" width="90" x="313" y="120"> <parameter key="set_iteration_macro" value="true"/> <parameter key="iterations" value="%{attributeCount}"/> <process expanded="true" height="439" width="1003"> <operator activated="true" class="extract_macro" compatibility="5.3.000" expanded="true" height="60" name="Extract Macro (2)" width="90" x="45" y="30"> <parameter key="macro" value="attributeName"/> <parameter key="macro_type" value="data_value"/> <parameter key="attribute_name" value="Field"/> <parameter key="example_index" value="%{iteration}"/> <list key="additional_macros"/> </operator> <operator activated="true" class="recall" compatibility="5.3.000" expanded="true" height="60" name="Recall" width="90" x="179" y="30"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <operator activated="true" class="rename" compatibility="5.3.000" expanded="true" height="76" name="Rename" width="90" x="313" y="30"> <parameter key="old_name" value="att%{iteration}"/> <parameter key="new_name" value="%{attributeName}"/> <list key="rename_additional_attributes"/> </operator> <operator activated="true" class="remember" compatibility="5.3.000" expanded="true" height="60" name="Remember (2)" width="90" x="648" y="30"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_port="input 1" to_op="Extract Macro (2)" to_port="example set"/> <connect from_op="Recall" from_port="result" to_op="Rename" to_port="example set input"/> <connect from_op="Rename" from_port="example set output" to_op="Remember (2)" to_port="store"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_output 1" spacing="0"/> </process> </operator> <operator activated="true" class="recall" compatibility="5.3.000" expanded="true" height="60" name="Recall (2)" width="90" x="447" y="120"> <parameter key="name" value="data"/> <parameter key="io_object" value="ExampleSet"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Remember" to_port="store"/> <connect from_op="Read Database" from_port="output" to_op="Extract Macro" to_port="example set"/> <connect from_op="Extract Macro" from_port="example set" to_op="Loop" to_port="input 1"/> <connect from_op="Recall (2)" from_port="result" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
