Dear members,
I have a quite simple question. If I want to integrate rapidminer process to my java application without instalation rapidminer on my computer, what I need to do?
ex: my code is:
import com.rapidminer.tools.OperatorService;
import com.rapidminer.RapidMiner;
import com.rapidminer.Process;
import com.rapidminer.operator.Operator;
import com.rapidminer.operator.OperatorException;
import java.io.IOException;
public class ProcessCreator {
public static Process createProcess() {
try {
// invoke init before using the OperatorService
RapidMiner.init();
} catch (IOException e) { e.printStackTrace(); }
// create process
Process process = new Process();
try {
// create operator
Operator inputOperator =
OperatorService.createOperator(ExampleSetGenerator.class);
// set parameters
inputOperator.setParameter("target_function", "sum classification");
// add operator to process
process.getRootOperator().addOperator(inputOperator);
// add other operators and set parameters
} catch (Exception e) { e.printStackTrace(); }
return process;
public static void main(String[] argv) {
// create process
Process process = createProcess();
// print process setup
System.out.println(process.getRootOperator().createProcessTree(0));
try {
// perform process
process.run();
// to run the process with input created by your application use
// process.run(new IOContainer(new IOObject[] { ... your objects ... });
} catch (OperatorException e) { e.printStackTrace(); }
how can I run this code, if I didn't install rapidminer or eclipse?
Thank you for your answer
