<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="539" width="1957"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="112" y="75"> <parameter key="repository_entry" value="//NewLocalRepository/temp_5000sampled_MI4"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.2.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="246" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="sex"/> <list key="comparison_groups"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.008" expanded="true" height="94" name="Normalize" width="90" x="380" y="75"/> <operator activated="false" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="715" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="event"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="76" name="Multiply" width="90" x="514" y="75"/> <operator activated="false" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples (2)" width="90" x="849" y="255"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="event=t"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="849" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="event=f"/> </operator> <operator activated="false" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="1050" y="165"> <parameter key="k" value="572"/> <parameter key="measure_types" value="MixedMeasures"/> </operator> <operator activated="true" class="k_medoids" compatibility="5.2.008" expanded="true" height="76" name="Clustering (2)" width="90" x="1117" y="30"> <parameter key="k" value="572"/> </operator> <operator activated="true" class="extract_prototypes" compatibility="5.2.008" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="1318" y="30"/> <operator activated="false" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes (2)" width="90" x="1050" y="300"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="cluster"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="false" class="union" compatibility="5.2.008" expanded="true" height="76" name="Union" width="90" x="1452" y="165"/> <operator activated="false" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes (3)" width="90" x="1586" y="165"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="false" class="shuffle" compatibility="5.2.008" expanded="true" height="76" name="Shuffle" width="90" x="1720" y="165"/> <connect from_op="Retrieve" from_port="output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Clustering (2)" to_port="example set"/> <connect from_op="Clustering (2)" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="391" width="748"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="k_medoids" compatibility="5.3.000" expanded="true" height="76" name="Clustering" width="90" x="246" y="75"/> <operator activated="true" class="extract_prototypes" compatibility="5.3.000" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="447" y="30"/> <operator activated="true" class="join" compatibility="5.3.000" expanded="true" height="76" name="Join" width="90" x="581" y="120"> <parameter key="use_id_attribute_as_key" value="false"/> <list key="key_attributes"> <parameter key="att1" value="att1"/> <parameter key="att2" value="att2"/> <parameter key="att3" value="att3"/> </list> </operator> <connect from_op="Generate Data" from_port="output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Clustering" from_port="clustered set" to_op="Join" to_port="right"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Join" to_port="left"/> <connect from_op="Join" from_port="join" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="391" width="748"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="set_role" compatibility="5.3.000" expanded="true" height="76" name="Set Role" width="90" x="179" y="75"> <parameter key="name" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="k_medoids" compatibility="5.3.000" expanded="true" height="76" name="Clustering" width="90" x="313" y="75"/> <operator activated="true" class="extract_prototypes" compatibility="5.3.000" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="447" y="75"/> <operator activated="true" class="set_role" compatibility="5.3.000" expanded="true" height="76" name="Set Role (2)" width="90" x="581" y="75"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Clustering" to_port="example set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.3.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.3.000" expanded="true" name="Process"> <process expanded="true" height="391" width="748"> <operator activated="true" class="generate_data" compatibility="5.3.000" expanded="true" height="60" name="Generate Data" width="90" x="45" y="75"> <parameter key="target_function" value="random classification"/> <parameter key="number_of_attributes" value="3"/> </operator> <operator activated="true" class="multiply" compatibility="5.3.000" expanded="true" height="94" name="Multiply" width="90" x="179" y="75"/> <operator activated="true" class="k_medoids" compatibility="5.3.000" expanded="true" height="76" name="Clustering" width="90" x="313" y="75"/> <operator activated="true" class="extract_prototypes" compatibility="5.3.000" expanded="true" height="76" name="Extract Cluster Prototypes" width="90" x="447" y="75"/> <operator activated="true" class="k_nn" compatibility="5.3.000" expanded="true" height="76" name="k-NN" width="90" x="313" y="210"/> <operator activated="true" class="apply_model" compatibility="5.3.000" expanded="true" height="76" name="Apply Model" width="90" x="581" y="165"> <list key="application_parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Clustering" to_port="example set"/> <connect from_op="Multiply" from_port="output 2" to_op="k-NN" to_port="training set"/> <connect from_op="Clustering" from_port="cluster model" to_op="Extract Cluster Prototypes" to_port="model"/> <connect from_op="Extract Cluster Prototypes" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="k-NN" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="36"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="539" width="1957"> <operator activated="true" class="retrieve" compatibility="5.2.008" expanded="true" height="60" name="Retrieve" width="90" x="45" y="75"> <parameter key="repository_entry" value="//NewLocalRepository/temp_5000sampled_MI4"/> </operator> <operator activated="true" class="sample_stratified" compatibility="5.2.008" expanded="true" height="76" name="Sample (Stratified)" width="90" x="179" y="255"> <parameter key="sample" value="relative"/> </operator> <operator activated="true" class="nominal_to_numerical" compatibility="5.2.008" expanded="true" height="94" name="Nominal to Numerical" width="90" x="246" y="75"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="sex"/> <list key="comparison_groups"/> </operator> <operator activated="true" class="normalize" compatibility="5.2.008" expanded="true" height="94" name="Normalize" width="90" x="380" y="75"/> <operator activated="false" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes" width="90" x="179" y="345"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="event"/> <parameter key="invert_selection" value="true"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply" width="90" x="581" y="75"/> <operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples (2)" width="90" x="782" y="255"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="event=t"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.008" expanded="true" height="76" name="Filter Examples" width="90" x="782" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="event=f"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.008" expanded="true" height="94" name="Multiply (2)" width="90" x="916" y="30"/> <operator activated="true" class="k_means" compatibility="5.2.008" expanded="true" height="76" name="Clustering" width="90" x="1117" y="30"> <parameter key="k" value="5"/> <parameter key="max_runs" value="100"/> <parameter key="measure_types" value="MixedMeasures"/> </operator> <operator activated="true" class="apply_model" compatibility="5.2.008" expanded="true" height="76" name="Apply Model" width="90" x="1117" y="120"> <list key="application_parameters"/> </operator> <operator activated="true" class="union" compatibility="5.2.008" expanded="true" height="76" name="Union" width="90" x="1385" y="210"/> <operator activated="true" class="select_attributes" compatibility="5.2.008" expanded="true" height="76" name="Select Attributes (3)" width="90" x="1519" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="id"/> <parameter key="invert_selection" value="true"/> <parameter key="include_special_attributes" value="true"/> </operator> <operator activated="true" class="shuffle" compatibility="5.2.008" expanded="true" height="76" name="Shuffle" width="90" x="1720" y="210"/> <connect from_op="Retrieve" from_port="output" to_op="Sample (Stratified)" to_port="example set input"/> <connect from_op="Sample (Stratified)" from_port="example set output" to_op="Nominal to Numerical" to_port="example set input"/> <connect from_op="Nominal to Numerical" from_port="example set output" to_op="Normalize" to_port="example set input"/> <connect from_op="Normalize" from_port="example set output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Union" to_port="example set 2"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Multiply (2)" to_port="input"/> <connect from_op="Multiply (2)" from_port="output 1" to_op="Clustering" to_port="example set"/> <connect from_op="Multiply (2)" from_port="output 2" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Clustering" from_port="cluster model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Union" to_port="example set 1"/> <connect from_op="Union" from_port="union" to_op="Select Attributes (3)" to_port="example set input"/> <connect from_op="Select Attributes (3)" from_port="example set output" to_op="Shuffle" to_port="example set input"/> <connect from_op="Shuffle" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
