I would like to make an own extension of RapidMiner. During my search for suitable libraries I've run into licence compatibility issues.
I want to use one particular library for my extension whose source code is not available to public and therefore incompatible with AGPL. However,
based on FAQ at gnu.org I learned this obstacle can be overcomed if _all_of_ copyright holders of AGPL code which is used in extension authorise an additional permission which allows mixing AGPL and closed-source parts.
The question I would like to ask is - is it possible to obtain this additional permission? I suspected it is likely to be too cumbersome to contact all contributors, but then I noticed the joint copyright assignment. Then I wondered if it means that rapid-i company has the rights to contributions to the code and has the option to give this additional permission.
Vin
