<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.006" expanded="true" name="Process"> <process expanded="true" height="341" width="815"> <operator activated="true" class="retrieve" compatibility="5.2.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="165"> <parameter key="repository_entry" value="//Samples/data/Golf"/> </operator> <operator activated="true" class="multiply" compatibility="5.2.006" expanded="true" height="94" name="Multiply" width="90" x="256" y="137"/> <operator activated="true" class="filter_examples" compatibility="5.2.006" expanded="true" height="76" name="Filter Examples" width="90" x="447" y="30"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="Play = yes"/> </operator> <operator activated="true" class="sample" compatibility="5.2.006" expanded="true" height="76" name="Sample" width="90" x="581" y="30"> <parameter key="sample_size" value="8"/> <list key="sample_size_per_class"/> <list key="sample_ratio_per_class"/> <list key="sample_probability_per_class"/> </operator> <operator activated="true" class="filter_examples" compatibility="5.2.006" expanded="true" height="76" name="Filter Examples (2)" width="90" x="447" y="210"> <parameter key="condition_class" value="attribute_value_filter"/> <parameter key="parameter_string" value="Play = no"/> </operator> <operator activated="true" class="sample_bootstrapping" compatibility="5.2.006" expanded="true" height="76" name="Sample (Bootstrapping)" width="90" x="593" y="209"> <parameter key="sample" value="absolute"/> <parameter key="sample_size" value="8"/> </operator> <operator activated="true" class="append" compatibility="5.2.006" expanded="true" height="94" name="Append" width="90" x="773" y="109"/> <connect from_op="Retrieve" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Filter Examples" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_op="Filter Examples (2)" to_port="example set input"/> <connect from_op="Filter Examples" from_port="example set output" to_op="Sample" to_port="example set input"/> <connect from_op="Sample" from_port="example set output" to_op="Append" to_port="example set 1"/> <connect from_op="Filter Examples (2)" from_port="example set output" to_op="Sample (Bootstrapping)" to_port="example set input"/> <connect from_op="Sample (Bootstrapping)" from_port="example set output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
