<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.008"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.008" expanded="true" name="Process"> <process expanded="true" height="641" width="1048"> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification" width="90" x="244" y="102"> <list key="attribute_values"> <parameter key="x" value=""b""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="generate_data_user_specification" compatibility="5.2.008" expanded="true" height="60" name="Generate Data by User Specification (2)" width="90" x="246" y="210"> <list key="attribute_values"> <parameter key="x" value=""a""/> </list> <list key="set_additional_roles"/> </operator> <operator activated="true" class="append" compatibility="5.2.008" expanded="true" height="94" name="Append" width="90" x="514" y="165"/> <operator activated="true" class="sort" compatibility="5.2.008" expanded="true" height="76" name="Sort" width="90" x="648" y="165"> <parameter key="attribute_name" value="x"/> </operator> <operator activated="true" class="generate_attributes" compatibility="5.2.008" expanded="true" height="76" name="Generate Attributes" width="90" x="782" y="165"> <list key="function_descriptions"> <parameter key="x" value="x"/> </list> </operator> <connect from_op="Generate Data by User Specification" from_port="output" to_op="Append" to_port="example set 1"/> <connect from_op="Generate Data by User Specification (2)" from_port="output" to_op="Append" to_port="example set 2"/> <connect from_op="Append" from_port="merged set" to_op="Sort" to_port="example set input"/> <connect from_op="Sort" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/> <connect from_op="Generate Attributes" from_port="original" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="126"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
