Write WordList a text file (txt) [SOLVED]
jose
New Altair Community Member
I have a process that reads an excel file. and then process the excel file using the operator "process document".
The output of this operator (wordlist), I write it to a text file (txt) but do not know what operator to use to accomplish this.
the xml of process is...
<process version="5.2.003">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process">
<process expanded="true" height="370" width="614">
<operator activated="true" class="read_excel" compatibility="5.2.003" expanded="true" height="60" name="Read Excel" width="90" x="45" y="120">
<parameter key="excel_file" value="/home/pepe/Escritorio/documentos de prueba/Septiembre.xls"/>
<parameter key="imported_cell_range" value="A1:CE522"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="�Qu� es lo que m�s te ha gustado de Vueling y quieres que sigamos haciendo, o por el contrario, lo que menos te ha gustado y nos sugieres cambiar? .true.text.attribute"/>
</list>
<operator activated="true" class="text:process_document_from_data" compatibility="5.2.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="75">
<parameter key="vector_creation" value="Term Occurrences"/>
<parameter key="prune_method" value="absolute"/>
<parameter key="prune_below_absolute" value="2"/>
<parameter key="prune_above_absolute" value="9999"/>
<list key="specify_weights"/>
<process expanded="true" height="505" width="636">
<operator activated="true" class="text:tokenize" compatibility="5.2.001" expanded="true" height="60" name="Tokenize" width="90" x="103" y="58"/>
<operator activated="true" class="text:transform_cases" compatibility="5.2.001" expanded="true" height="60" name="Transform Cases" width="90" x="246" y="75"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="5.2.001" expanded="true" height="60" name="Filter Stopwords (Dictionary)" width="90" x="45" y="165">
<parameter key="file" value="/home/pepe/Escritorio/documentos de prueba/stop words.txt"/>
<operator activated="true" class="text:filter_by_length" compatibility="5.2.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="112" y="255"/>
<operator activated="true" class="text:replace_tokens" compatibility="5.2.001" expanded="true" height="60" name="Replace Tokens" width="90" x="246" y="255">
<list key="replace_dictionary">
<parameter key="horas" value="hora"/>
<parameter key="maletas" value="maleta"/>
<parameter key="vuelos" value="vuelo"/>
<parameter key="precios" value="precio"/>
<parameter key="asientos" value="asiento"/>
<parameter key="Vueling" value="vueling"/>
<parameter key="MALETAS" value="maleta"/>
<parameter key="VUELOS" value="vuelo"/>
</list>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="5.2.001" expanded="true" height="60" name="Generate n-Grams (Terms)" width="90" x="380" y="255"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
<connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Replace Tokens" to_port="document"/>
<connect from_op="Replace Tokens" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Read Excel" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents from Data" from_port="word list" to_port="result 2"/>
</process>
</process>
Hi Jose,
you can use the WordList to Data operator to convert the Wordlist to an example set and then write it to disk with e.g. Write CSV.
All the best,
Marius0 -
Thanks Marius.
You are a genius.0
