<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="198" width="522"> <operator activated="true" class="retrieve" compatibility="5.2.003" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="loop_values" compatibility="5.2.003" expanded="true" height="76" name="Loop Values" width="90" x="179" y="30"> <parameter key="attribute" value="label"/> <process expanded="true" height="216" width="540"> <operator activated="true" class="web:read_rss" compatibility="5.1.004" expanded="true" height="60" name="Read RSS Feed" width="90" x="112" y="30"> <parameter key="url" value="http://www.rsssearchhub.com/feeds/?search=%{loop_value}&amp;action=Search+Feeds"/> <parameter key="random_user_agent" value="true"/> </operator> <connect from_op="Read RSS Feed" from_port="output" to_port="out 1"/> <portSpacing port="source_example set" spacing="0"/> <portSpacing port="sink_out 1" spacing="0"/> <portSpacing port="sink_out 2" spacing="0"/> </process> </operator> <connect from_op="Retrieve" from_port="output" to_op="Loop Values" to_port="example set"/> <connect from_op="Loop Values" from_port="out 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
