<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="116" width="614"> <operator activated="true" class="text:create_document" compatibility="5.2.001" expanded="true" height="60" name="Create Document" width="90" x="112" y="30"> <parameter key="text" value="first second line"/> </operator> <operator activated="true" class="text:documents_to_data" compatibility="5.2.001" expanded="true" height="76" name="Documents to Data" width="90" x="313" y="30"> <parameter key="text_attribute" value="text"/> </operator> <operator activated="true" class="replace" compatibility="5.2.003" expanded="true" height="76" name="Replace" width="90" x="514" y="30"> <parameter key="replace_what" value="(\n)"/> </operator> <connect from_op="Create Document" from_port="output" to_op="Documents to Data" to_port="documents 1"/> <connect from_op="Documents to Data" from_port="example set" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
