<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.003"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.003" expanded="true" name="Process"> <process expanded="true" height="500" width="950"> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data" width="90" x="246" y="75"/> <operator activated="true" class="self_organizing_map" compatibility="5.2.003" expanded="true" height="94" name="SOM" width="90" x="447" y="75"> <parameter key="number_of_dimensions" value="1"/> </operator> <operator activated="true" class="generate_data" compatibility="5.2.003" expanded="true" height="60" name="Generate Data (2)" width="90" x="447" y="210"/> <operator activated="true" class="apply_model" compatibility="5.2.003" expanded="true" height="76" name="Apply Model" width="90" x="648" y="120"> <list key="application_parameters"/> </operator> <connect from_op="Generate Data" from_port="output" to_op="SOM" to_port="example set input"/> <connect from_op="SOM" from_port="example set output" to_port="result 1"/> <connect from_op="SOM" from_port="preprocessing model" to_op="Apply Model" to_port="model"/> <connect from_op="Generate Data (2)" from_port="output" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="Apply Model" from_port="labelled data" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
