<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.2.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.2.000" expanded="true" name="Process"> <parameter key="parallelize_main_process" value="true"/> <process expanded="true" height="386" width="835"> <operator activated="true" class="read_database" compatibility="5.2.000" expanded="true" height="60" name="Read Database (2)" width="90" x="45" y="30"> <parameter key="connection" value="slave2"/> <parameter key="query" value="SELECT label, data, school_list_holiday_sources.id FROM school_list_holiday_data INNER JOIN school_list_holiday_sources ON school_list_holiday_data.id=school_list_holiday_sources.id WHERE school_list_holiday_sources.label = "true" OR isGood = -2 AND school_list_holiday_sources.label = "false" LIMIT 0,200"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.000" expanded="true" height="76" name="Nominal to Text" width="90" x="179" y="30"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="data"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.1.004" expanded="true" height="76" name="Process Documents from Data" width="90" x="313" y="30"> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="absolute"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="999"/> <list key="specify_weights"/> <process expanded="true" height="480" width="815"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.004" expanded="true" height="60" name="Extract Content" width="90" x="45" y="120"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.004" expanded="true" height="60" name="Transform Cases" width="90" x="179" y="120"/> <operator activated="true" class="text:tokenize" compatibility="5.1.004" expanded="true" height="60" name="Tokenize" width="90" x="313" y="120"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.004" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="120"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.004" expanded="true" height="60" name="Stem (Snowball)" width="90" x="581" y="120"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.004" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="715" y="120"> <parameter key="min_chars" value="2"/> </operator> <connect from_port="document" to_op="Extract Content" to_port="document"/> <connect from_op="Extract Content" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/> <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Stem (Snowball)" to_port="document"/> <connect from_op="Stem (Snowball)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/> <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="90"/> <portSpacing port="sink_document 1" spacing="90"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="read_database" compatibility="5.2.000" expanded="true" height="60" name="Read Database" width="90" x="45" y="210"> <parameter key="connection" value="slave2"/> <parameter key="query" value="SELECT data, label, isGood, school_list_holiday_sources.id FROM school_list_holiday_data INNER JOIN school_list_holiday_sources ON school_list_holiday_data.id=school_list_holiday_sources.id WHERE label != "true" AND isGood = 0 LIMIT 0,2000"/> <enumeration key="parameters"/> </operator> <operator activated="true" class="nominal_to_text" compatibility="5.2.000" expanded="true" height="76" name="Nominal to Text (2)" width="90" x="179" y="210"> <parameter key="attribute_filter_type" value="single"/> <parameter key="attribute" value="data"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="5.1.004" expanded="true" height="76" name="Process Documents from Data (2)" width="90" x="313" y="210"> <parameter key="keep_text" value="true"/> <parameter key="prune_method" value="absolute"/> <parameter key="prune_below_absolute" value="2"/> <parameter key="prune_above_absolute" value="999"/> <list key="specify_weights"/> <process expanded="true" height="340" width="803"> <operator activated="true" class="web:extract_html_text_content" compatibility="5.1.004" expanded="true" height="60" name="Extract Content (2)" width="90" x="45" y="30"/> <operator activated="true" class="text:transform_cases" compatibility="5.1.004" expanded="true" height="60" name="Transform Cases (2)" width="90" x="180" y="30"/> <operator activated="true" class="text:tokenize" compatibility="5.1.004" expanded="true" height="60" name="Tokenize (2)" width="90" x="315" y="30"/> <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.004" expanded="true" height="60" name="Filter Stopwords (2)" width="90" x="450" y="30"/> <operator activated="true" class="text:stem_snowball" compatibility="5.1.004" expanded="true" height="60" name="Stem (2)" width="90" x="585" y="30"/> <operator activated="true" class="text:filter_by_length" compatibility="5.1.004" expanded="true" height="60" name="Filter Tokens (2)" width="90" x="703" y="30"> <parameter key="min_chars" value="2"/> </operator> <connect from_port="document" to_op="Extract Content (2)" to_port="document"/> <connect from_op="Extract Content (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/> <connect from_op="Transform Cases (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/> <connect from_op="Tokenize (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/> <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Stem (2)" to_port="document"/> <connect from_op="Stem (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/> <connect from_op="Filter Tokens (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" compatibility="5.2.000" expanded="true" height="76" name="Set Role (2)" width="90" x="447" y="210"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="set_role" compatibility="5.2.000" expanded="true" height="76" name="Set Role" width="90" x="447" y="30"> <parameter key="name" value="label"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="naive_bayes" compatibility="5.2.000" expanded="true" height="76" name="Naive Bayes" width="90" x="581" y="30"> <parameter key="laplace_correction" value="false"/> </operator> <operator activated="true" class="apply_model" compatibility="5.2.000" expanded="true" height="76" name="Apply Model (2)" width="90" x="715" y="120"> <list key="application_parameters"/> </operator> <connect from_op="Read Database (2)" from_port="output" to_op="Nominal to Text" to_port="example set input"/> <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Process Documents from Data" from_port="word list" to_op="Process Documents from Data (2)" to_port="word list"/> <connect from_op="Read Database" from_port="output" to_op="Nominal to Text (2)" to_port="example set input"/> <connect from_op="Nominal to Text (2)" from_port="example set output" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Set Role (2)" to_port="example set input"/> <connect from_op="Set Role (2)" from_port="example set output" to_op="Apply Model (2)" to_port="unlabelled data"/> <connect from_op="Set Role" from_port="example set output" to_op="Naive Bayes" to_port="training set"/> <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model (2)" to_port="model"/> <connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 1"/> <connect from_op="Apply Model (2)" from_port="model" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="90"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator></process>
A ResultSet object is automatically closed when the Statement object that generated it is closed, re-executed, or used to retrieve the next result from a sequence of multiple results.
SELECT label, data, school_list_holiday_sources.id FROM school_list_holiday_data INNER JOIN school_list_holiday_sources ON school_list_holiday_data.id=school_list_holiday_sources.id WHERE school_list_holiday_sources.label = "true" OR isGood = -2 AND school_list_holiday_sources.label = "false" LIMIT 0,200"/>SELECT data, label, isGood, school_list_holiday_sources.id FROM school_list_holiday_data INNER JOIN school_list_holiday_sources ON school_list_holiday_data.id=school_list_holiday_sources.id WHERE label != "true" AND isGood = 0 LIMIT 0,2000"/>
