Hi
when i applying optimize selection using genetic algorithm and applied it on Libsvm, its select me Some feature with accuracy please apply this
<process version="5.1.014">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.014" expanded="true" name="Process">
<process expanded="true" height="607" width="480">
<operator activated="true" class="retrieve" compatibility="5.1.014" expanded="true" height="60" name="iris" width="90" x="45" y="30">
<parameter key="repository_entry" value="//Samples/data/Iris"/>
<operator activated="true" class="optimize_selection" compatibility="5.1.014" expanded="true" height="94" name="Optimize Selection" width="90" x="380" y="30">
<parameter key="selection_direction" value="backward"/>
<parameter key="limit_number_of_generations" value="true"/>
<process expanded="true" height="607" width="852">
<operator activated="true" class="x_validation" compatibility="5.0.000" expanded="true" height="112" name="Validation" width="90" x="380" y="30">
<description>A cross-validation evaluating a decision tree model.</description>
<process expanded="true" height="654" width="165">
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.014" expanded="true" height="76" name="SVM" width="90" x="45" y="30">
<list key="class_weights"/>
<connect from_port="training" to_op="SVM" to_port="training set"/>
<connect from_op="SVM" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<process expanded="true" height="654" width="300">
<operator activated="true" class="apply_model" compatibility="5.0.000" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.1.014" expanded="true" height="76" name="Performance" width="90" x="180" y="30">
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<connect from_port="example set" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="averagable 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
</process>
<connect from_op="iris" from_port="output" to_op="Optimize Selection" to_port="example set in"/>
<connect from_op="Optimize Selection" from_port="example set out" to_port="result 1"/>
<connect from_op="Optimize Selection" from_port="weights" to_port="result 2"/>
<connect from_op="Optimize Selection" from_port="performance" to_port="result 3"/>
</process>
</process>
but when i token this feature and run again without applying Optimize selection; its give me another accuracy; please apply that
<context>
<input/>
<output/>
<macros/>
</context>
<process expanded="true" height="287" width="547">
<operator activated="true" class="select_attributes" compatibility="5.1.014" expanded="true" height="76" name="Select Attributes" width="90" x="246" y="75">
<parameter key="attributes" value="a3|a4|"/>
<operator activated="true" class="x_validation" compatibility="5.1.014" expanded="true" height="112" name="Validation" width="90" x="447" y="75">
<process expanded="true" height="607" width="401">
<operator activated="true" class="support_vector_machine_libsvm" compatibility="5.1.014" expanded="true" height="76" name="SVM" width="90" x="112" y="30">
</process>
<operator activated="true" class="apply_model" compatibility="5.1.014" expanded="true" height="76" name="Apply Model" width="90" x="45" y="30">
<operator activated="true" class="performance_classification" compatibility="5.1.014" expanded="true" height="76" name="Performance" width="90" x="179" y="30">
<parameter key="classification_error" value="true"/>
</process>
<connect from_op="iris" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="training" to_port="result 1"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
</process>
</process>
so what can i done??
thanks
