Optimizing with Rohacell core in optistruct
I'm trying to mass optimize a model with various loadcases acting on it... I want the result to have a rohacell core of constant thickness throughout the centre of the entire panel (to be left alone during the optimization) so I have two questions regarding this,
1)how can the core be left at say 5mm and not split up and shuffled in the stack during free sizing?
and 2) why do I get massive out of plane displacement when using the listed properties for a core material such as rohacell 71 and running an analysis?
Thanks for any and all help!
Hi SSnell,
1) You can use CONST option in DSIZE to give a constant thickness constraint.
2) have a look at RANGE option in DSHUFFLE card. For your case you may require 2 RANGE bounds.
Altair Forum User said:why do I get massive out of plane displacement when using the listed properties for a core material such as rohacell 71 and running an analysis?
Are the applied loads are inplane loads?
The out of plane displacement could be a result from coupling effect.
If you can share the model, I can investigate about the out of plane displacements.
0 -
Thanks for the DSIZE-CONST advice,
The applied loads are out of plane and when analysing with the laminate set to Total it gives huge displacement perpendicular to the surface, Is there anywhere I can read/learn about this coupling effect to try and understand it? and maybe the best place to learn about analysing and optimizing models with a core in hypermesh?thanks
0 -
You can refer to any book which deals with laminate stiffness analysis. So the deformation depends on the way the laminate is stacked. For instance for a non-symmetric laminate, upon application of a tensile load there will be certain amount of bending in the structure.
But one of the assumptions for calculation of laminate stiffness is the stress are in-plane.
