"generate a report by loop"
currant
Dear All,
I want to use the loop operators of RM to generate a report:
In a survey we had a lot of questions. For each question I want to
create a bars-plot for each question on single page within a pdf-file
So the loop should be based on the attribute "question", right? If so, is the operator "
Loop attributes
" the correct one? I tried this operator, but it does not work ...
Thanks in advance!
BW
currant
Loops + Branches
colo
Hi currant,
if you have each question as an example in your example set, you should use "Loop Examples". Otherwise you might have to give a little info about the structure of your data, if you need further suggestions.
Regards
Matthias
currant
Dear Matthias, dear all
here is my table:
question
YearTxt
Mean
07
2006
3,4
07
2011
3,9
08
2006
2,4
08
2011
1,5
09
2006
4,0
09
2011
2,2
so, the loop should generate a bar plot for the question 07 on one side of the pdf-file, then on the
next side
of the pdf-file the bar plot for
question 08
and so on.
Probably it is very easy to design the loop process, but ...
Thanks a lot
currant
currant
Hi All,
... after hours of searching and testing, I found out how to introduce the loop...
I use now the
Loop Values
-operator (select the attribute "question"; set the iteration macro = loop_value);
inside the loop value-operator I use the "
Filter example
"-operator with
condition class = attribute_value_filter
and
parameter string = "question = %{loop_value}"
I hope some other people can use this process-info.
currant
tbwhite
Currant,
Thank you so much, this post was a huge help, I'd be struggling with the same problem for a while now.
