I'm just getting started with RapidMiner (v 1.0 on Mac), but I'm having a pretty tough time getting over this initial hurdle. I've got my data in a csv. When I try to import it I step through the wizard and everything looks like it's fine, up to the point where I pick a location for the data and save it. Then, without fail, I get the message
Cannot store object at '//repoName/projectName/data'.
I've tried a number of different data files and pieces of data files, reformatted data with different separators, and tried a couple of different repo/project locations. Unfortunately I keep getting the same result. I'm including a stack trace below in case that helps. I'm an experienced engineer but pretty much a babe in the woods with Java and with RapidMiner, so I'm not really set up to do much line-by-line debugging.
Any help would really be appreciated
