RSS Feeds Classification Process
montaqi
montaqi New Altair Community Member
I am working on a process that I read bbc worlds news from its rss url then I predict positive/negative to each news as well as over all news.
I have built two text files containing positive words and negative words. Following is my XML, but somehow the result generated is not what I want. The result from this process only predicts 4 words, which is very strange. What am I doing wrong?
<process version="5.1.006">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
    <process expanded="true" height="460" width="614">
      <operator activated="true" class="text:process_document_from_file" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Files" width="90" x="45" y="30">
        <list key="text_directories">
          <parameter key="positive" value="C:\Documents and Settings\TU001YU\Desktop\positive"/>
          <parameter key="negative" value="C:\Documents and Settings\TU001YU\Desktop\negative"/>
        </list>
        <process expanded="true" height="524" width="806">
          <operator activated="true" class="text:transform_cases" compatibility="5.1.001" expanded="true" height="60" name="Transform Cases" width="90" x="112" y="75"/>
          <operator activated="true" class="text:tokenize" compatibility="5.1.001" expanded="true" height="60" name="Tokenize" width="90" x="313" y="75">
            <parameter key="mode" value="linguistic tokens"/>
          <connect from_port="document" to_op="Transform Cases" to_port="document"/>
          <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/>
          <connect from_op="Tokenize" from_port="document" to_port="document 1"/>
        </process>
      <operator activated="true" class="web:read_rss" compatibility="5.1.000" expanded="true" height="60" name="Read RSS Feed" width="90" x="45" y="345">
        <parameter key="url" value="http://feeds.bbci.co.uk/news/world/rss.xml"/>
        <parameter key="random_user_agent" value="true"/>
      <operator activated="true" class="text:process_document_from_data" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="255">
        <list key="specify_weights"/>
          <operator activated="true" class="text:transform_cases" compatibility="5.1.001" expanded="true" height="60" name="Transform Cases (2)" width="90" x="45" y="30"/>
          <operator activated="true" class="text:tokenize" compatibility="5.1.001" expanded="true" height="60" name="Tokenize (2)" width="90" x="179" y="30"/>
          <operator activated="true" class="text:stem_porter" compatibility="5.1.001" expanded="true" height="60" name="Stem (Porter)" width="90" x="313" y="30"/>
          <operator activated="true" class="text:filter_stopwords_english" compatibility="5.1.001" expanded="true" height="60" name="Filter Stopwords (English)" width="90" x="447" y="30"/>
          <operator activated="true" class="text:filter_by_length" compatibility="5.1.001" expanded="true" height="60" name="Filter Tokens (by Length)" width="90" x="581" y="30">
            <parameter key="min_chars" value="2"/>
            <parameter key="max_chars" value="99"/>
          <connect from_port="document" to_op="Transform Cases (2)" to_port="document"/>
          <connect from_op="Transform Cases (2)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
          <connect from_op="Tokenize (2)" from_port="document" to_op="Stem (Porter)" to_port="document"/>
          <connect from_op="Stem (Porter)" from_port="document" to_op="Filter Stopwords (English)" to_port="document"/>
          <connect from_op="Filter Stopwords (English)" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
          <connect from_op="Filter Tokens (by Length)" from_port="document" to_port="document 1"/>
        </process>
      <operator activated="true" class="text:wordlist_to_data" compatibility="5.1.001" expanded="true" height="76" name="WordList to Data" width="90" x="380" y="165"/>
      <operator activated="true" class="naive_bayes_kernel" compatibility="5.1.006" expanded="true" height="76" name="Naive Bayes (Kernel)" width="90" x="246" y="30"/>
      <operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="Apply Model" width="90" x="447" y="30">
      <connect from_op="Process Documents from Files" from_port="example set" to_op="Naive Bayes (Kernel)" to_port="training set"/>
      <connect from_op="Process Documents from Files" from_port="word list" to_op="Process Documents from Data" to_port="word list"/>
      <connect from_op="Read RSS Feed" from_port="output" to_op="Process Documents from Data" to_port="example set"/>
      <connect from_op="Process Documents from Data" from_port="example set" to_port="result 3"/>
      <connect from_op="Process Documents from Data" from_port="word list" to_op="WordList to Data" to_port="word list"/>
      <connect from_op="WordList to Data" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
      <connect from_op="Naive Bayes (Kernel)" from_port="model" to_op="Apply Model" to_port="model"/>
      <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
      <connect from_op="Apply Model" from_port="model" to_port="result 2"/>
    </process>
</process>
  • land
    land New Altair Community Member
    sorry, but I think this process does not make any sense...
    You are building a naive bayes model that will just count positive against negative words. Ok, if you just want to classify according to these prepared word lists...
    But then you are retrieving an RSS feed, processing it according to the word list resulting from your two word list files. But you throw away the result and use the same wordlist that came in to classify? This is just senseless. Use the ExampleSet instead.
    Anyway this is not the way you usually use data mining. It would be much easier for you to write a script that counts the occurring of your words. Normally you will need the information for a small sample of posts, where they are positive or negative. Then the system will learn which words are positive and which negative automatically! Much more flexible...
    Greetings,
      Sebastian
  • montaqi
    Thank you for your reply Sebastian, I am new to Text Mining but I am trying to learn. I built this model following another post on this forum:
    http://rapid-i.com/rapidforum/index.php/topic,3078.0.html
    If I can classify text files using this model how come I cannot classify rss fees using the same model?
    Sebastian Land wrote:
    Greetings,
      Sebastian
  • Marco_Boeck
    Marco_Boeck New Altair Community Member
    you are using the wordlist instead of using the result of your lower Process Documents operator for classification.
    I corrected your process:
    <process version="5.1.008">
     <context>
       <input/>
       <output/>
       <macros/>
     </context>
     <operator activated="true" class="process" compatibility="5.1.008" expanded="true" name="Process">
       <process expanded="true" height="346" width="567">
           </list>
           </process>
         <operator activated="true" class="web:read_rss" compatibility="5.1.000" expanded="true" height="60" name="Read RSS Feed" width="90" x="45" y="165">
         <operator activated="true" class="text:process_document_from_data" compatibility="5.1.001" expanded="true" height="76" name="Process Documents from Data" width="90" x="246" y="120">
           </process>
         <operator activated="true" class="naive_bayes_kernel" compatibility="5.1.008" expanded="true" height="76" name="Naive Bayes (Kernel)" width="90" x="246" y="30"/>
         <operator activated="true" class="apply_model" compatibility="5.1.008" expanded="true" height="76" name="Apply Model" width="90" x="447" y="30">
         <connect from_op="Process Documents from Data" from_port="example set" to_op="Apply Model" to_port="unlabelled data"/>
       </process>
    </process>
    If you're interested in text mining, you may want to check out our webinars, for example this one: http://rapid-i.com/component/page,shop.product_details/flypage,garden_flypage.tpl/product_id,63/category_id,16/option,com_virtuemart/Itemid,180/vmcchk,1/lang,en/
    Marco
