I am currently working on a project that I want to read rss feeds from a list of rss urls. I built the following process, but somehow it has error and cannot go through. Please help me...as I think it should be a simple problem, but I just can't figure out somehow...
the csv file only contains five rows:
News
http://feeds.bbci.co.uk/news/rss.xmlhttp://feeds.bbci.co.uk/news/world/rss.xmlhttp://feeds.bbci.co.uk/news/uk/rss.xmlhttp://feeds.bbci.co.uk/news/business/rss.xmlMy XML looks like below:
<process version="5.1.006">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Process">
<process expanded="true" height="449" width="614">
<operator activated="true" class="read_csv" compatibility="5.1.006" expanded="true" height="60" name="Read CSV" width="90" x="45" y="120">
<parameter key="csv_file" value="C:\Documents and Settings\TU001YU\Desktop\RSSLoop.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="skip_comments" value="true"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations"/>
<parameter key="0" value="att1.true.polynominal.attribute"/>
</list>
<operator activated="true" class="loop_values" compatibility="5.1.006" expanded="true" height="94" name="Loop Values" width="90" x="246" y="120">
<parameter key="attribute" value="att1"/>
<process expanded="true" height="524" width="806">
<operator activated="true" class="web:read_rss" compatibility="5.1.000" expanded="true" height="60" name="Read RSS Feed" width="90" x="120" y="32">
<parameter key="url" value="%{loop_value}"/>
<connect from_op="Read RSS Feed" from_port="output" to_port="out 1"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="example set"/>
<connect from_op="Loop Values" from_port="out 1" to_port="result 1"/>
<connect from_op="Loop Values" from_port="out 2" to_port="result 2"/>
</process>
</process>
