<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.1.006"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="5.1.006" expanded="true" name="Root"> <process expanded="true" height="584" width="815"> <operator activated="true" class="retrieve" compatibility="5.1.006" expanded="true" height="60" name="Retrieve" width="90" x="45" y="30"> <parameter key="repository_entry" value="../../data/Sonar"/> </operator> <operator activated="true" class="split_data" compatibility="5.1.006" expanded="true" height="94" name="Split Data" width="90" x="246" y="30"> <enumeration key="partitions"> <parameter key="ratio" value="0.7"/> <parameter key="ratio" value="0.3"/> </enumeration> <parameter key="sampling_type" value="stratified sampling"/> </operator> <operator activated="true" class="decision_tree" compatibility="5.1.006" expanded="true" height="76" name="DecisionTree" width="90" x="447" y="30"/> <operator activated="true" class="apply_model" compatibility="5.1.006" expanded="true" height="76" name="Apply Model" width="90" x="581" y="165"> <list key="application_parameters"/> </operator> <operator activated="true" class="performance_classification" compatibility="5.1.006" expanded="true" height="76" name="Performance" width="90" x="648" y="30"> <list key="class_weights"/> </operator> <connect from_op="Retrieve" from_port="output" to_op="Split Data" to_port="example set"/> <connect from_op="Split Data" from_port="partition 1" to_op="DecisionTree" to_port="training set"/> <connect from_op="Split Data" from_port="partition 2" to_op="Apply Model" to_port="unlabelled data"/> <connect from_op="DecisionTree" from_port="model" to_op="Apply Model" to_port="model"/> <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/> <connect from_op="Apply Model" from_port="model" to_port="result 3"/> <connect from_op="Performance" from_port="performance" to_port="result 1"/> <connect from_op="Performance" from_port="example set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> <portSpacing port="sink_result 4" spacing="0"/> </process> </operator></process>
nawafpower wrote:Hello Guys,Any update regarding my last post? I didn't hear a response from Neil or any one ? Is there any thing need to be clarified in my post? let me know and I appreciate any help.
