"Loop Parameters over a collection of strings"
arc12
HI -
I can see how Loop Parameters works to loop over numerical values but I want to set a parameter with a string type.
Specifically, I want to set the URL parameter for the "Read RSS Feed" operation from a list of URLs,
I've experimented, googled and searched these email forums but got nowhere.
Is this possible somehow?
Cheers, Adam
Loops + Branches
ImageMiner
maybe read your urls from a file via "Read Excel" operator. Then make a "Loop Values" over the attribute holding the urls.
Inside operator "Read RSS" use the macro %{loop_value} as value for "url".
The name "loop_value" is defined inside the loop operator, so you can use self defined names, too.
Hope this helps
ImageMiner
arc12
Thanks imageminer; that was just the info I needed. Simple when you know how!
For the benefit of others, below is the XML for a how-to-do-it. NB I used the CSV reader, which requires metadata be set. The easiest way to get this right is to use the "wizard". In my case below there was a fist column with entries I discard.
Cheers, Adam
<process version="5.1.004">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="5.1.004" expanded="true" name="Process">
<process expanded="true" height="325" width="413">
<operator activated="true" class="read_csv" compatibility="5.1.004" expanded="true" height="60" name="Read CSV" width="90" x="55" y="162">
<parameter key="csv_file" value="[path to file]/feeds.csv"/>
<parameter key="column_separators" value=","/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="type.false.text.attribute"/>
<parameter key="1" value="url.true.text.attribute"/>
</list>
<operator activated="true" class="loop_values" compatibility="5.1.004" expanded="true" height="76" name="Loop Values" width="90" x="246" y="255">
<parameter key="attribute" value="url"/>
<process expanded="true" height="593" width="614">
<operator activated="true" class="web:read_rss" compatibility="5.1.000" expanded="true" height="60" name="Read RSS Feed" width="90" x="112" y="147">
<parameter key="url" value="%{loop_value}"/>
<connect from_op="Read RSS Feed" from_port="output" to_port="out 1"/>
</process>
<connect from_op="Read CSV" from_port="output" to_op="Loop Values" to_port="example set"/>
<connect from_op="Loop Values" from_port="out 1" to_port="result 1"/>
</process>
</process>
