how to work with the modified document?
<?xml version="1.0" encoding="UTF-8" standalone="no"?><process version="5.0"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" expanded="true" name="Process"> <process expanded="true" height="339" width="795"> <operator activated="true" class="web:read_rss" expanded="true" height="60" name="Read RSS Feed" width="90" x="112" y="210"> <parameter key="url" value="http://newsrss.bbc.co.uk/rss/newsonline_world_edition/front_page/rss.xml"/> <parameter key="random_user_agent" value="true"/> </operator> <operator activated="true" class="web:retrieve_webpages" expanded="true" height="60" name="Get Pages" width="90" x="313" y="120"> <parameter key="link_attribute" value="Link"/> <parameter key="page_attribute" value="text"/> </operator> <operator activated="true" class="text:process_document_from_data" expanded="true" height="76" name="Process Documents from Data" width="90" x="488" y="119"> <parameter key="create_word_vector" value="false"/> <parameter key="keep_text" value="true"/> <list key="specify_weights"/> <process expanded="true" height="353" width="808"> <operator activated="true" class="text:extract_length" expanded="true" height="60" name="Extract Length" width="90" x="188" y="47"/> <operator activated="true" class="text:extract_information" expanded="true" height="60" name="Extract Information" width="90" x="386" y="45"> <parameter key="query_type" value="Regular Region"/> <list key="string_machting_queries"> <parameter key="Title" value="<Body>.</Body>"/> </list> <list key="regular_expression_queries"> <parameter key="Title" value="<%title%[^>]*>(.*?)</%title%>"/> </list> <list key="regular_region_queries"> <parameter key="Title" value="<title>.</title>"/> </list> <list key="xpath_queries"/> <list key="namespaces"/> <list key="index_queries"/> </operator> <connect from_port="document" to_op="Extract Length" to_port="document"/> <connect from_op="Extract Length" from_port="document" to_op="Extract Information" to_port="document"/> <connect from_op="Extract Information" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="set_role" expanded="true" height="76" name="Set Role" width="90" x="623" y="115"> <parameter key="name" value="text"/> </operator> <connect from_op="Read RSS Feed" from_port="output" to_op="Get Pages" to_port="Example Set"/> <connect from_op="Get Pages" from_port="Example Set" to_op="Process Documents from Data" to_port="example set"/> <connect from_op="Process Documents from Data" from_port="example set" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator></process>
